    Veteran Member Four Rings Black_Pearl_B6's Avatar
    Aug 11 2010
    Agawam Ma
    Calling all electrical experts
    My car is equipped with Audi drive select, and I just installed Air suspension so now I have a suspension fault light on the dash, so basically what I am asking is if there is a way to delete that like the kit from KW without spending 600 which is likely just resistors, so my questions are
    1. Is there a way to tell if they use a resistor
    2. if they do is there a way to put a multimeter on the wires and check resistance to tell what resistor is needed
    3. has anyone found a solution for this problem?
    09 Prestige Package
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    can you just recode?
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Aug 11 2010
    Agawam Ma
    Quote Originally Posted by AudiTechS4 View Post
    that's one option I am pursuing as I already sent a email to davidb8 who is the coding wizard, I am still awaiting his reply
    09 Prestige Package
    Aug 11 2010
    Agawam Ma
    bueller bueller
    09 Prestige Package
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    http://www.audienthusiasts.com/VagCom_FL_ADS.html
    Have you tried unchecking the box for "Magnetic Ride Suspension Installed" like in the link above?
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
