Results 1 to 12 of 12
Thread: P0011
    Jun 28 2015
    San Francisco
    P0011
    Got a B6 S4 and this P0011 code came on. Wondering if anyone had experience with it?
    P0011 = A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
    Established Member Two Rings ajbuckner's Avatar
    Feb 01 2016
    Loveland, CO
    Quote Originally Posted by aaronboy86 View Post
    Same code with mine... Most likely a warn cam adjuster. Common problem on older b6s
    Nov 12 2015
    Oregon
    Causes:
    A P0011 DTC trouble code may be caused by one or more of the following:
    Incorrect camshaft timing
    Wiring problems (harness/wiring) in intake
    timing control valve control solenoid system
    Continuous oil flow to VCT piston chamber
    Failed timing valve control solenoid (stuck open)
    first..check to make sure you dont have oil flow issues. If im not mistaken, this code is common among the adjusters being worn out or failing. They rely on oil pressure.
    this video shows for the other bank, but its basically the same
    https://www.youtube.com/watch?v=AiTiJ5mnvQ4
    Now im not saying that this is exactly what is going on there.... but its a good start. Do you have VCDS? Have you done a full scan and not just the generic scan?
    My build log
    Veteran Member Four Rings evildsmr's Avatar
    Sep 13 2012
    04 Imola V8, '21 Army Green Taco
    Denver
    Yes get vcds ASAP and go into the engine module and then select measuring blocks and type in 091 enter 092 enter 093 enter and report back these values more specifically the cam phase degrees in the measuring block 093.
    Sent from my Nexus 6 using Tapatalk
    Jun 28 2015
    San Francisco
    Thanks guys, I took it to JHM. They told me the bank 1 adjusters are failing. I'll need a Full timing job. Anybody know of other creative fixes?
    Feb 18 2014
    Arizona
    Sorry to hear about the issue, OP. Unfortunately the only fix for a failed adjuster is to replace it.
    Quote Originally Posted by evildsmr View Post
    can you elaborate on what to look for in those measuring blocks? I wish someone would've chimed in to help me understand them when I posted screenshots of those blocks and specifically asked if they could be used to diagnose timing issues...
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Get her done!!
    Sent from my SM-G900T using Audizine mobile app
    Feb 01 2016
    Loveland, CO
    Anyone in the Northern Colorado area experienced with this code and know how to fix it? I want to fix mine without blowing 10k at the dealer when someone experienced could help me do it for a 10th of that price
    Aug 09 2012
    Bay Area
    Quote Originally Posted by ajbuckner View Post
    I do remember seeing a DYI write up on this a while ago. They didn't have to pull the motor or anything. It was a tight squeeze but he got it done from the top.
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    That's probably a bit optimistic...
    B6 S4 Cabriolet
    Milltek exhaust w/ SW tips, H9 fogs (DRL), denison Ipod adapter.
    Debadged except the rings, TWM Leopard shift knob.
    TD Pro Race 1.2 Wheels, Continental Extreme Contact DWS.
    Sep 13 2012
    Denver
    Where at in NoCo?
    Feb 01 2016
    Loveland, CO
    Where at in NoCo?
    Loveland/ft Collins/Greeley
