I removed the rear drive shaft and rear differential from my 2004 1.8 A 4with a 6 speed manual transmission. I removed all of the bolts holding the drive shaft to the rear differential. I expected the drive shaft to be easily separated from the differential but that is not the case. I have tried tapping around the drive shat flange with a hammer spraying with PB blaster applying some heat using the drive shaft like a slide hammer as there is about an inch of play in the slip joint. There is a little bit of movement but it doesn't separate. Anyone have any insight into what's going on or any ideas on how to separate them I would like to hear your solution I don't want to damage the differential
