Results 1 to 3 of 3
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    New Noise WTF. Please help.
    So today i started my car in the a.m for work. as soon as the car was warming up I hear like a humming noise coming from the engine( I belive is the engine) so when i'm applying throttle gently is like hum hum hum hum with a whistle sound. As soon as i left off the gas and put it in neutral coasting sound goes away...car has 100k miles so new noises anybody have an idea? Car isn't vibrating or anything. But it seems a little laggy then before.
    Sent from my C5306 using Tapatalk
    Ivan
    Veteran Member Four Rings i3oricua's Avatar
    Sep 17 2006
    2022 Kia Sorento; 2015 Ducati Monster 821 Dark
    Aurora, Colorado
    Likely your diverter valve. Theres some posts in the DYI I believe that tells you which version to purchase or if you want to upgrade.
    Aug 20 2013
    Miami
    Quote Originally Posted by i3oricua View Post
    Thanks foe your reply man i was thinking the same thing imma go with revision d i know is not the best for performance but i need realability.
    Ivan
