Hartmann RS4 DTM 18" Wheels / Yokohama Tires - Audi B5 A4 S4
18" Hartmann RS4 DTM Wheels & Yokohama Parada Spec 2 Tires
Time to take off those winter wheels and replace them with - ONE - of a kind Hartmann RS4 DTM style 9 spoke wheels. Professionally custom finished - Machined Face and Gray Powder Coated inner spokes, originally OEM Gloss Silver color. They are in immaculate shape NO curb damage, cracks, or bends. When they were refinished one wheel had a small hairline crack that was professionally repaired, no issues balancing or with leaks. The only negative thing is one of the valves needs to be replaced, it has started to leak very slowly, will include 4 new valves. The unmistakable DTM style is highlighted by a nice concave shape and exposed wheel bolts.
Wheels specs are 18x8 Et 35 5x112, center bore 66.56
Wheel / Tire Set Comes with:
Yokohama Parada Spec 2 tires, 225/40ZR18 92W
OEM Audi center caps and blank black center caps
20 conical wheels bolts for proper fitment
Low pressure cast aluminum alloy (same as OEM manufacturing), Heat treated for high strength, and Tested to JWL, VIA, and TUV standards
These wheels sit flush with the fenders on the Audi B5 platform. Don't miss out!!
List Date: 4/22/2016
For more info, click here to view the original listing: Hartmann RS4 DTM 18" Wheels / Yokohama Tires - Audi B5 A4 S4
This item is no longer available.
