Results 1 to 18 of 18
    Apr 17 2012
    2001 Audi A4 1.8t Quattro; 1994 Jeep Grand Cherokee 5.2l
    Red Deer, Alberta
    Viscous fan info
    Before I get flamed to hell and back I have searched through many forums and gathered lots of information on the efc I intend to do. I just am having trouble finding what the cfm of the stock clutch viscous fan. I've only found a poor selection of universal fans where I live, and the only 14" I found is 3 5/8" deep and only moves 1250cfm. Would this be adequate or should I just order one online. I am willing to do some trimming if required. So if someone could provide me stock cfm that would be awesome.
    Nov 03 2011
    All Over!
    Quote Originally Posted by davyboy View Post
    Adequate for what's? Trimming what / where? You don't mention what car this is for, not enough detail.
    1986 Type 85 Audi 90 quattro
    Apr 17 2012
    Red Deer, Alberta
    Sorry thought I had that setup to shop up on posts. 2001 a4 1.8t quattro
    The viscous clutch rad fan is what I wanna know cfm on.
    Jul 27 2011
    IN
    Its available for just $11 from ecstuning, why don't you buy this ?
    https://www.ecstuning.com/Search/Sit...01B/ES2535167/
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Quote Originally Posted by woolveren View Post
    hes going to a efk like all modern cars use. and a lot of us have swapped to.
    I would order one online op, I run a spal 14inch slim its like 2inch thick
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    Quote Originally Posted by tar View Post
    I probably run the same fan as you. It's 3+ years old and still works. Never had a problem with it *knock on wood*.
    2011 Audi A4 Avant Prestige S-Line
    2001 Corvette (C5) Z06
    Apr 17 2012
    Red Deer, Alberta
    http://m.summitracing.com/parts/spu-ix-30100385
    Is this the one you guys are running?
    The only spal slims I saw run 1000-1250 cfm ish
    Jul 07 2009
    Socal/IE
    Ya I think that's it, cheaper on this site
    www.a1electric.com/Merchant2
    Apr 17 2012
    Red Deer, Alberta
    Cool, gonna compair some prices, I just wasn't sure that 1200 cfm was enough which is why I was trying to figure out the clutch fans cfm rating.
    Apr 17 2012
    Red Deer, Alberta
    Also I'd be willing to do the trimming for a 16" with 1600 cfm if that's gonna be more than the stock will move so it has to run less time to achieve the same cooling effect if it's of any more benefit than the 14" with 1200.
    Assuming the stock moves about 1000 cfm either would be better (correct me if I'm wrong on this).
    Jul 07 2009
    Socal/IE
    Dude u live in Canada don't worry about it. Just do the 14inch
    Me and metal live in so cal where its regularly over 100f.
    And plenty of other members who live in hot states run 14inch
    Apr 17 2012
    Red Deer, Alberta
    I hate reviving my old threads, did you use the wiring kit and sensor from a1 electric? I'm just wondering as it looks like it would have to be threaded into a line but I have no idea where I could thread it in or if I should get a different sensor? I'd like to order it ASAP, I think clutch fan gonna fail soon based on the noises it's making lol. Thanks again.
    Jul 07 2009
    Socal/IE
    I used the summit racing wiring setup with built in relay and temp probe
    Senior Member Three Rings OMEGA SUPREME's Avatar
    Mar 29 2007
    Gig Harbor
    I only run the stock electric fan. Took off the fan clutch. Temp never moves, even on track day.
    Apr 17 2012
    Red Deer, Alberta
    I'd still feel better with a second fan, and with the kits on there they all say the temp probe/thermostat is the screw in type, wondering where/how you installed it?
    Nov 03 2011
    All Over!
    You could go with a stainless steel bridge in the upper hose, with a threaded boss to accept the screw-in thermo switch.
    Apr 17 2012
    Red Deer, Alberta
    I like the idea but wouldn't it have to be in the lower rad hose as upper feeds the rad so will always be at high temp meaning fan would always be on?
    Apr 17 2012
    Red Deer, Alberta
    You wouldn't happen to know the diameter of the upper and lower rad hoses would you, I've found some bridges with ports for these just wanna get the right size.
