This is seriously driving me crazy.
So I am planning on doing the oil check valve service and perhaps installing JHM intake spacers, and I came across a post that had recommendations for other work that I could perform while I have the intake manifold out. I cannot find it and I've used the forum search tool with every keyword I could remember.
I am basically interested in knowing which parts I can access/fix related to the timing chain system when I have the intake manifold off. Ideally I'd buy JHM's aluminum parts to replace the OEM plastic ones.
While I am in there I will also be performing a simple fix suggested by Squiddy that will alleviate the problem with the intake manifold flap getting stuck:
http://www.audizine.com/forum/showth...-and-Read-Here
Also, here is a link to the DIY guide for the oil check valve service, should make for an interesting Sunday:
http://bd8ba3c866c8cbc330ab-7b26c6f3...llation_R1.pdf
