Results 1 to 11 of 11
    Mar 21 2015
    Southern California
    Misfire Issue And Slight Knocking Advise Needed Please
    I have a 2000 S4 Stage 3 and am having a small issue. When I first start the car in the morning and drive for the first 10-15 minutes everything is perfect, the car drives and idles fine. After the 15 minutes, it develops a slight misfire and what sounds like a slight knock. I have no check engine light on at the moment but I did try and get it smogged the other day and 5 minutes in to the process the CEL popped on. The guy was nice enough to pull the plug before it could transfer anymore but the code that it came up with was a misfire in "cylinder 4". The next day the check engine light went off by itself and has not come on since but the issue is still there. Before I go out and spend a lot of money on new coils and plugs, some opinions would be appreciated. Thank you in advance!
    Dec 10 2013
    Borden, Ontario, Canada
    Swap the coils and plug to a different cylinder. If it follows, then you can then swap the coil with another cylinder. If it does not follow you need a new plug. If it does follow the coil, you need a coil
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Clearly the FPR is failing
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Jul 04 2012
    Woodbridge, VA
    Unfortunately misfires can be hard to diagnose because it is usually a side effect of some other issue. I would start by looking at ignition related items:
    1) Check Coil: Move the coil to a different cylinder. If it follows to the new cylinder you have found the issue.
    2) Plug and Plug gaps: Check the health of the plug. Plugs are pretty cheap (OEM NKG for ~$2 each) so maybe its a good time to change and gap the plugs.
    3) ICM: Swap the ICMs. Located on the airbox, you should be able to simply swap the wiring without having to unbolt the ICMs.
    4) Vacuum leak: This can easily cause misfires. No recommendation on troubleshooting. This will also cause misfires on other cylinders as well. Have you logged all 6? Its not until the misfire count reaches a certain number that it sends a CEL code.
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by Timtheguru View Post
    Lmao!
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    When my lifter failed I had knocking and a misfire
    Veteran Member Four Rings treysgreen's Avatar
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    Have the heads ever been replaced?
    02 A4 5spd 1.8T Quattro ///
    01 S4 6MT /// - SOLD
    Instagram - s4mods ///
    http://s4mods.com ///
    Mar 21 2015
    Southern California
    Quote Originally Posted by treysgreen View Post
    Yes, they are 2.8 heads but the knocking is very light.
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    Misfires could be indicative of a valve kissing the piston at some point. If a ridge is created in the piston it could misfire once the car heats up due to it creating a Hotspot and causing ignition.
    Mar 21 2015
    Southern California
    The heads were done in 2008 and I have never heard it before. Would it take this long?
    Jan 03 2014
    02 A4 1.8t Quattro
    Atlanta
    Quote Originally Posted by sidewayzgt View Post
    I don't think so but it just something to consider if you've exhausted all other options.
