Results 1 to 31 of 31
    Established Member Two Rings verstappen's Avatar
    May 05 2014
    B5 S4, B6 S4, B8.5 A4, 11 Audi Q5
    Phoenix
    Flywheel, CLutch noise
    whats up folks, I finished my stage 3 car a few weeks ago, I put about 400 miles on it and everything was dandy, it was about to get tuned but unfortunately Daz passed and now I was waiting to have Blake tune it.. but something strange is happening and I am fearing the worst... I started my car this morning and I heard a rattle coming from the flywheel/clutch.. it goes away when I depress the clutch, I started driving and the noise is increasing with RPM then it goes away past 3k, the thing is that the noise wasn't there, it just started today.
    I have a vast alum fw, rs4 pp and a clutchnet 6 puck Kevlar disc.. everything felt perfect for a few weeks, not anymore... what do you guys think? loose flywheel?? bad pilot bearing?
    flywheel was torqued as per manual with all new hardware, and also the pp.. new pilot bearing, new to bearing... wtf?
    With your mind power, your determination, your instinct, and the experience as well, you can fly very high.
    -Ayrton Senna
    Sep 11 2009
    NE
    I always had a slight rattle in my aluminum flywheel back in days when I have stage 3 kind of kit with RS4 pp, it would go away with clutch pressed in. Now, does the noise then change with change in load of engine? E.g, when you lug it at 2k rpms, does it change with how much gas pedal you press in? I think you have two kinds of noise in there, something rattling and classic clutch chatter, or rather tranny gears rattling, which you get as a reward for spending money on aluminum flywheel.
    May 05 2014
    Phoenix
    Quote Originally Posted by julex View Post
    So on idle it goes away past 1200 rpm + or -, driving around it goes away but comes back when deccelerating on gear, so approaching a light, I let off the gas on gear and the rattle comes back.
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Check any heat shields around there and tighten them up..
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Veteran Member Three Rings Sumo337's Avatar
    Jan 07 2015
    2011 B8S4
    Pittsburgh, PA
    Probably loose flywheel.
    @chetbagged
    2011 B8S4 Prestige
    460HP-384TQ Manual
    APR / ECS / P3 / WCI / Sportshifters / Polo Performance / Airlift / Caractere
    May 05 2014
    Phoenix
    Quote Originally Posted by Sumo337 View Post
    Indeed, I wonder how this bitch came loose, now I have to pull the damn engine again FML. I might just take it to the shop at this point, took me 3 months to pull my engine because I have no time available. Awesome...
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Maybe too long flywheel bolts?
    May 05 2014
    Phoenix
    Quote Originally Posted by okkim View Post
    I guess? the flywheel had machined slightly where the bolts sit.. this sucks, now I need to pull the engine again. :( I almost want to pay someone to do it haha
    -Ayrton Senna
    Dec 30 2009
    Quote Originally Posted by verstappen View Post
    Check your heat shields first...
    2001.5 S4 Sedan
    2018 Q5 2.0t
    May 05 2014
    Phoenix
    Quote Originally Posted by Timtheguru View Post
    I will, I will jack up the car in a bit, see what's going on there.
    -Ayrton Senna
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    If it had circles machined for the bolt heads and you didnt use washers
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    May 05 2014
    Phoenix
    Quote Originally Posted by zillarob View Post
    Yeah... it was machined for the bolt heads, no washers. Now I know. Time to do this again...
    Nov 16 2010
    WetSide, WA
    Its prob time for a new motor.
    This is one of the dragons that lurks in these cars.
    When you bottom the bolts out like that, it destroys the thrust surface on the crank and crushes the thrust bearings.
    May 05 2014
    Phoenix
    No effin way! Damn is this that bad??? Engine runs great! Fuck! Oh man... I need a drink.
    Nov 16 2010
    WetSide, WA
    I did a clutch in one once and found it like that.
    No telling how long it had been that way or how much further it would have gone.
    May 05 2014
    Phoenix
    This really sucks, fuck, what a mistake to make. How did you come across that? Why did you put the engine appart?
    Nov 16 2010
    WetSide, WA
    Was doing a clutch on it at first and noticed the end of the bolts were jacked.
    Dude had another crank and wanted rods so fixed it proper.
    You can roll the dice and run it. If it made it this far you might get lucky.
    Prob cheaper to buy a new motor than to fix it right.
    May 05 2014
    Phoenix
    I will start the engine pull on Sunday, I might just run the engine for now, it has high miles too so who knows how long it will last. I will get an engine and start building it to have as a spare. Thanks for the input, I would have never thought this was so serious.
    Nov 16 2010
    WetSide, WA
    Its only slightly better than putting one of the tranny bolts in the wrong spot and blowing a hole in the #6 cyl wall.
    You may be good, you caught it before the fw broke off at least.
    Now just hope you can get the bolts out without chewing up the holes in the crank.
    Really no way of saying how long it will last and I would prob run it also. Cross country trips might make me a little nervous though.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    You know this never made sense to me. So I get countersinking the bolts so bolt heads don't hit the clutch disc springs, but doesn't putting a washer in there space it back out and make countersinking pointless? THe thing to do is just cut the bolts down
    May 05 2014
    Phoenix
    Quote Originally Posted by DxC View Post
    Well, when I was installing the flywheel that is exactly what I was thinking, that it was room to clear the disc. Bolts torqued perfectly fine. I will pull the engine, inspect and post what I find.
    -Ayrton Senna
    May 05 2014
    Phoenix
    Are you serious? I did notice the trans bolts have a spot, I numbered them upon removal. That would be a shitty problem to have, has this ever happened to someone? I am guessing so since you are aware of it. I appreciate your input Zillarob, I owe you a cold one.
    -Ayrton Senna
    Nov 16 2010
    WetSide, WA
    I always kinda thought they put the steel washer in there to keep the bolts from chewing into the alum.
    Bolts heads are only a prob with aftermarket type disks and as I recall they were big fans of modding stock parts.
    Nov 16 2010
    WetSide, WA
    I think monty had a pic of that carnage from somewhere. Hole blown right through the cyl wall.
    May 05 2014
    Phoenix
    that's nuts... so glad it didn't happen, I would be at my desk at work crying right now, looking for an engine.
    -Ayrton Senna
    Nov 16 2010
    WetSide, WA
    This is what you are up against if you want to get a head start.
    http://www.audizine.com/forum/showth...highlight=lear
    May 05 2014
    Phoenix
    wow that looks messed up, well I hope my shit is not as bad, thankfully I haven't beat on the car yet, and right when I heard the noise I parked the car. I need to drive around the block to get to the garage in the back of my house, maybe I should get some help to push it. If my stuff is reusable (except hardware of course) Should I place washers on the bolts or cut the bolts? what do you suggest? Do you happen to know the thickness of a OEM disc? I know my disc is 240mm as per clutchnet.
    -Ayrton Senna
    Nov 16 2010
    WetSide, WA
    I think your biggest concern is the fw bolts coming back out. Hope they dont shear off and the threads in the crank are ok if they come out.
    I think the holes in the crank are ~12mm deep, but only threaded ~10mm so the tips of the bolts will prob be mushed.
    The bolt thing can be tough.
    Clutchnet is the flat aftermarket style disk and doesnt like how high the oem bolt heads sit from a fw with oem dimentions.
    You can measure 8 times (maybe 12 times just to be safe) then cut oem bolts shorter, or measure 8 times (again, maybe 12) and use washers and normal length aftermarket bolts with shorter heads.
    Both are 240mm. Oem will be about 12mm loose, or 10mm compressed. Clutchnet is prob 8mm and no marcels so it wont compress and will drive like shit.
    Nov 03 2011
    All Over!
    This is one of the reasons I prefer SM steel flywheels, with a stock depth in the bolt area.
    1986 Type 85 Audi 90 quattro
    Sep 11 2009
    NE
    Some guy in europe literally locked his crank this way, posted no crank thread etc, etc, etc in the end they took apart the engine and found the thrust washers had literally dimples in them...
    May 05 2014
    Phoenix
    wow!! hahaha how messed up. I am not even going to check my engine, if it pops oh well. But I guess I am buying a spare and start building it.
    -Ayrton Senna
