Results 1 to 4 of 4
Thread: Rear fog lights
    Feb 15 2016
    Cambridge,Ontario
    Rear fog lights
    Hi guys
    3rd Audi. Previous ones had rear drivers only.
    My a4b7 has an error right rear fog light out. Huh ?? So I go check. And notice when you put rear fogs on both light up for a second then one goes out and I get the error.
    So I swap the bulbs. And now the other side does it. So....,,
    1. Does the b7 have two rear fogs
    2. Does it only give an error because it sees it then it goes out ?
    3. I noticed rear fogs are two different sizes. One looks like a regular tail light bulb silver base. The other looks like a short stubby bulb with a much smaller glass bulb with a silver base. Is one of them wrong ?
    Many thanks as always.
    Feb 15 2016
    Cambridge,Ontario
    Additional info
    Thinking that maybe it was because it saw the light then it went out I removed that bulb, so it only had a bulb in the drivers side. Same thing " right rear fog light out" . The owners manual states there is only a drivers side fog light. So now I am thinking maybe someone went in and turned on the second fog light option through VCDS ( europen config ) any thoughts ? , for now im juat gonna get another 21w bulb and slap it in the other side to keep the warning light off.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings a4audi4fun's Avatar
    Sep 28 2007
    2017 B9 A4 Technik 6 spd manual, S-Line , 2008 B7 2.0T Avant 6MTQS S-Line, Past-2005 B6 A4 3.0 6MTQS
    Vancouver, BC, Canada
    FWIW - my Canadian B7 Avant has 2 rear foglights - the bulbs used are the ones that are on the hatch portion.
    Feb 15 2016
    Cambridge,Ontario
    Thanks , I went to CT and picked up a couple of 21w bulbs, popped one in the right side and all is solved.
    1976 Yamaha XS 360
