Results 1 to 29 of 29
    Established Member Two Rings BasicA6's Avatar
    Feb 16 2016
    Puyallup, Washington
    Cam chain tensioner and chain change
    I am planning to change both can chains and tensioners tonight. Can someone help me out and post the link for the how to please? I know this is a horse that has been beaten multiple times but I'm on my phone and honestly too lazy to look.
    Feb 16 2016
    no one to help a brother out? lol
    Current: 2000 Stock 4.2L A6
    Previous: 2003 300FWHP SRT-4, 2004 800AWHP EVO VIII
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    For the chain driven V8 there should
    be a DIY in the b6 s4 section. Google
    search it. Also I think JHM makes a
    DIY dvd but am not %100 sure.
    Jul 20 2015
    Corolla
    Indianapolis
    I found a bunch of youtube vids on this
    Sep 16 2010
    Central Wash
    Passenger side just do it exactly the way it looks; get stuff out of the way and remove all spark plugs and valve covers. I mark the cam positions to the head, mark the chain position to the cam also. Mark these spots very clearly and thoroughly and you dont need to count links between cams, just line everything up [i]exactly]/i] the way it was.
    Be VERY very careful with the torx bolts for the cam caps. Mark those and make sure each goes back exactly where you removed it.
    Drivers side is the same, but it's pretty impossible without removing timing belt.
    Feb 16 2016
    Quote Originally Posted by rollerton View Post
    thanks bud i am out there now taking everything apart the drivers side is not bad but i bout everything tensioners and chains for both side so i am just gonna go ahead and do both.
    Feb 16 2016
    took this out tonight it was toasted thank goodness i order a new chain as well
    the driver side looks like it was replaced recently before the car was purchased
    Senior Member Three Rings Arsenal2012's Avatar
    Aug 20 2015
    Chicago
    WTF, did u have a lot of rattle?
    Feb 16 2016
    i just started the car one morning and there was an abundant amount of rattle, before that there was no rattle at all. the car ran for about 3-6 mins then i parked it until the parts came in.
    Feb 16 2016
    the bottom was the worse idk looks like it was rubbing for a while but i did not hear any rattle at all. looks like when the top plastic broke thats when it made the noise
    Jul 20 2015
    Corolla
    Indianapolis
    were you able to fish out any of the broken plastic bits from the guides? That damage is exactly what I was afraid of on mine, my guides look OK now, but another member told me that they'll look OK up until the moment the break and crumble, then your tensioners are eff'd, like yours. gonna replace mine just for good measure.
    Sep 16 2010
    Central Wash
    Hey!! We're matchers!! Can I be in the club!?
    Feb 16 2016
    Quote Originally Posted by AvantHater View Post
    yes i was able to fish out all the broken plastic pieces last night I'm putting all back together tonight and hopefully start her up tomorrow after i change the oil
    - - - Updated - - -
    yes we should start a club lol
    Veteran Member Four Rings V1nny's Avatar
    Dec 04 2012
    Arlington VA
    How did you do both sides without removing timing belt? Is it really possible?
    Sep 16 2010
    Central Wash
    Quote Originally Posted by V1nny View Post
    No! I mean, I don't think it's technically impossible but I don't think he did it. The pic I posted is from passenger side also.
    Active Member Two Rings JBX's Avatar
    Jan 11 2015
    SS, MD
    Basic/Rolleton,
    What was your approximate mileages on your engines at the bad tensioner replacement? The reason I ask is that I am at 106K and would really like to put this tensioner replacement off until the TB job at 150+K (which is probably 6 years for me).
    Thanks.
    --jb
    02S6 6MT, A3 3.2 S-Line, 02 EVWE, CBX, Duc ST4S, 3rd Gen Rx-7, 96 Bronco Sport w/Kenne-Bell S/C
    Sep 16 2010
    Central Wash
    Quote Originally Posted by JBX View Post
    Basic/Rolleton,
    Thanks.
    --jb
    Both the ones I did were 4.2's. And I did one a couple weeks ago which is at 165k and the tensioner was NOISY on cold startup but removed with just some wear on the pads, no other damage.
    That one from yesterday is at 209,000 miles! and was MOAR noisy for slightly longer at startup most of the time but ran quiet. And..came out looking like that. Both are from Bank1. I always do that side first in the hopes that bank2 (drivers side) has no issues.
    Personally, since I can't find an issue with the chinese parts so far and they're pretty affordable- I'm probably going to just start replacing the tensioners when I do a service on engines w/ more than 150k- at the very least the drivers side since the TB has to be removed for that one. The ENTIRE tensioner kit with all gaskets is under $300. Can't really argue against it and risk a problem in 20k miles.
    I think these issues are pretty rare at less than 150k. But if you're doing the timing belt you might check the pads out.
    Feb 16 2016
    can someone post how to set the timing for the crank please i didnt insert the crank locking pin before i started to take the shit apart silly me.
    Sep 16 2010
    Central Wash
    Dude....no. No no no. Did you make any marks of any kind during reassembly? Mark everything, take pictures, count chain links. If anything moved at all you're in a heap o trouble.
    There are crank timing marks way down on the large crank pulley to-timing cover; personally I never look at them for this. I mark everything and make sure it stays put and reassemble. If anything moves at all while a cam is out you can run into puzzles.
    Hopefully the exhaust cam little slot still lines up with the mark on the bearing cap?
    If SO then good. Reassemble, line up intake cam to match it's mark and don't worry about the crank.
    Feb 16 2016
    I got it all back together but now I have a miss fire in 1-3-5-7 cylinder I don't know what I did wrong and I certainly do not want to tear it all apart again
    Apr 25 2016
    London, UK
    You might have to - I have just done the same job on my RS6 and you really need the cam lock bar and the crank locking pin. The TDC mark on the front pulley does't really line up accurately enough
    This is the tool: http://www.ebay.com/itm/BAUMTOOLS-VW...315455&vxp=mtr
    That tool goes over the two exhaust cams - it should go on easily. Did they line up like this (bigger hole of the two pointing in)? : Sorry image is here
    If that's OK, then the inlet camshaft may have become de-timed from the exhaust one. There are marks on each cam that should align with the marks on the bearing caps. Each side has a different amount of chain linkages between the tops of the cam when putting eveything back together.
    Hope that helps.
    Sep 16 2010
    Central Wash
    Man, that sucks. But honestly don't referencing crank timing doesn't help you on this job. You can do the cam-to-cam timing no matter where the crank is. As long as the cams are lined up to each other properly you can time the exhaust cam to the crank almost anytime.
    I also say do one side at a time, Passenger side/ bank1 first, since it has nothing to do with the timing belt. Once bank1 is done if you still have trouble or want to, do bank2. But either way.
    I just did 3 of these and didn't look at the crank timing a single time. Remove valve cover and get the cams lined up with the notches on the ends, the when you're ready to remove them MARK THE CAM (both of them) position relative to the cam caps. You can see how I marked it in this pic:
    If you do this and reassemble with your marks lined up you can have no issues. Without the marks I made I would have been totally screwed on the last one; since I had to turn the engine over a few times with the intake cam removed. With no original reference I would have a headache.
    Also, ...you know that the tensioners are specific to each side? They can be swapped and the engine will run but you'll have misfires. The one that ends in 088 is Passenger side.
    Feb 16 2016
    I didn't mess with anything on the drivers side at all it was previously replaced but it threw a miss fire code on that side as well. I'm at a total loss I'm trying to figure out this miss fire issue now I will tear it back apart this weekend and try to fix it correctly
    Sep 16 2010
    Central Wash
    is your ONLY error code for misfires? You may want to check for vacuum leaks and anything else first. I've gotten cam / crank timing incorrect correlation errors when the timing was off.
    Senior Member Three Rings bpark1210's Avatar
    Jan 08 2016
    PNW N. of Seattle
    Check on this. That's what it sounds like to me. If it's all timed up w/ zero interference and you're having misfires you prob got the tensioners mixed up.
    Feb 16 2016
    I will look at it when I get home
    Feb 16 2016
    first of let me say thank you to roller ton i had the wrong tensioner in there 087 and it caused it to misfire, swapped it out in about an hour considering i just removed the valve cover marked the cams and removed the intake cams didnt have to redo timing or anything. put it back together and BOOM it worked.
    roller ton send me your paypal I'm going to send you $50 to buy a couple cases of beers!
    Sep 16 2010
    Central Wash
    Awesome!
    But I ain't takin your money. You're not that far away...maybe a beer someday!
    Feb 16 2016
    Just glad I got this worked out
