Results 1 to 7 of 7
    Established Member Two Rings Bklynjay's Avatar
    Jul 10 2012
    Brooklyn, NY
    Plastidip front chrome moldings. Pain in the ass but second try success
    Took a total time about 2 hours and now just drying. Tried yesterday but failed since I put the tape too close to the trim. Second try was much better results. Put on 4 coats of Plastidip and 3 coats of Plastidip Glossifier on the grill area only not fog trimmings to match the gloss on the grill. Sorry the outcome photo a bit blurry
    2010 A6.5 Quattro | G.I.A.C Stage I | Ibis white | Prestige Package | Side assist and cold weather package | 10% tint all around | Tinted tails | Debadged - only rear Audi Black rings | 7" TV headrest OEM bolt on with MMI | 2013 S4 19" Peelers | K6 Eyelids | Quad Rear Diffuser with Porsche 911 Exhaust Tips | Aluminum Pedals | DRL Fog LED Strip with on/off switch
    Jul 17 2011
    Sin City, USA
    Looks good. Nice thing about Plasti-dip is that you can peel it off if you make an error.
    '09 C6.5 A6
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Look good, yea I also learned the hard way you have to lay your tape about 6 inches away from what you are actually spraying and just peel it up and use a razor to get off the extra.
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    Definite improvement to the fog covers. Any close up shots of the finish?
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Jul 10 2012
    Brooklyn, NY
    I still have to rub off the overspray but you can see quality. Pretty good. Some advice. Try to work in a none debris / windy area when wet.
    Senior Member Two Rings se.farrell's Avatar
    Jan 10 2014
    Los Angeles, CA
    Quote Originally Posted by Bklynjay View Post
    Both look really good/smooth.
    Why did you decide to go with plasti-dip for the fogs? Do you plan of peeling the dip off in the future? Just wondering because it is a complex shape.
    FYI, I dipped my fogs, but subsequently peeled and painted.
    Current:
    C7 A6 3.0T Prestige - Glacier White
    STAGE 1 | TSW
    C6 A6 S-line - GONE
    Feb 19 2013
    Looks good!
    I've heard good things about AutoDip. Its vinyl based, so glossy by nature and supposedly easier to deal with. I have no direct experience other than with dip.
    Dead:
