Results 1 to 6 of 6
    Apr 03 2016
    California
    B8.5 B&O audio documentation/specifications?
    When I bought my '13 S4 I found a blown speaker in the front passenger side. They swapped it out for a new speaker quickly. Pretty easy to diagnose. I'm aware of the complaints on the B&O setup, but think there is still something wrong. For instance, people in the back seat say they don't hear much and everything is coming from the front. I have the fader set to dead center. When I play around with the setting, there is a significantly different sound profile depending on position. For instance, when set to far extreme rear drivers side, the volume is weak and no base. Rear passenger side and the base comes back, but muddy and not nearly as strong as when it's put in the extreme front drivers or passenger. Do I still have something wrong or is this normal?
    2013 S4 Prem+, Phantom Black, MMI+ Nav, black Nappa, Sports Diff, Advanced Key, Carbon Atlas inlays
    2012 Yukon Denali XL, White Diamond, fully loaded (wife's, yes she still has more HP than me)
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    Well most of the speakers are up front but that does not sound normal. Obviously we all know this system has no bass but there should be a decent amount of Clear Audio in the rear.
    I remember reading a thread somewhere (maybe Slacktide's?) which said the fader effects the sub. I find this to be poorly put together system with speakers run in parallel, no or insufficient crossovers, sub affected by fader, etc.
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by miztahsparklez View Post
    Well... I knew it wouldn't be long before I got the car audio itch. The B&O system just isn't cutting it for me. Good news for people looking to upgrade, I'm likely going to sell all the old B&O speakers. Bad news for me, I think I'm going to be spending some $$.
    Anyhow, has anyone tackled this yet? I've compiled a list of the wiring I may possibly need using the B8 A5/S5 B&O diagram.
    Connection From Amp - J525 BitOne Input Speaker Connector Pin Color Notes
    Center Speaker + CH1 + R158 T32h 5 Blue/White Changes to Blue/White at T17c, Pin 15
    Center Speaker - CH1 - R158 T32h 17 Black/White Changes to Black/White at T17c, Pin 17
    Front Left Tweeter + Use Combined R20 T27a 11 Red/Blue B101, Positive Front Left Speaker (Main Harness), not needed for BitOne
    Front Left Tweeter - Use Combined R20 T27a 24 Brown/Blue B102, Negative Front Left Speaker (Main Harness), not needed for BitOne
    Front Left Midrange + Use Combined R103 T17d 15 Red/Green B101, Positive Front Left Speaker (Main Harness), not needed for BitOne
    Front Left Midrange - Use Combined R103 T17d 17 Brown/Green B102, Negative Front Left Speaker (Main Harness), not needed for BitOne
    Front Left Tweeter/Midrange + CH2 + R20/R103 T32h 6 Red/Blue Shared with R20, R103, contains combined signal
    Front Left Tweeter/Midrange - CH2 - R20/R103 T32h 18 Brown/Blue Shared with R20, R103, contains combined signal
    Front Left Midbass + CH3 + R21 T32h 23 Red/Blue Changes to Red /Blue at T27a, Pin 20 (Main Harness)
    Front Left Midbass - CH3 - R21 T32h 28 Brown/Blue Changes to Brown/Blue at T27a, Pin 22 (Main Harness)
    Front Right Tweeter + Use Combined R22 T27c 11 Blue/White B103, Positive Front Right Speaker (Main Harness), not needed for BitOne
    Front Right Tweeter - Use Combined R22 T27c 24 Black/White B104, Negative Front Right Speaker (Main Harness), not neeeded for BitOne
    Front Right Midrange + Use Combined R104 T17f 15 Red/White B103, Positive Front Right Speaker (Main Harness), not needed for BitOne
    Front Right Midrange - Use Combined R104 T17f 17 Brown/White B104, Negative Front Right Speaker (Main Harness), not neeeded for BitOne
    Front Right Tweeter/Midrange + CH4 + R22/R104 T32h 5 Red/Yellow Shared with R22, R104, contains combined signal
    Front Right Tweeter/Midrange - CH4 - R22/R104 T32h 19 Brown/Yellow Shared with R22, R104, contains combined signal
    Front Right Midbass + CH5 + R23 T32h 10 Red/Yellow Changes to Red/Blue at T27c, Pin 20 (Main Harness)
    Front Right Midbass - CH5 - R23 T32h 22 Brown/Yellow Changes to Brown/Blue at T27c, Pin 22 (Main Harness)
    Rear Left Tweeter + Use Combined R14 B487 23 Red/Violet Shared with R159, not needed for BitOne
    Rear Left Tweeter - Use Combined R14 B486 22 Brown/Violet Shared with R159, not needed for BitOne
    Rear Left Midrange + x R105 T32h 8 Red/Gray
    Rear Left Midrange - x R105 T32h 20 Brown/Gray
    Rear Left Midbass + CH6 + R159 T32h 3 Red/Violet Shared with R14, contains full signal
    Rear Left Midbass - CH6 - R159 T32h 15 Brown/Violet Shared with R14, contains full signal
    Rear Right Tweeter + Use Combined R16 B485 21 White/Green Shared with R160, not needed for BitOne
    Rear Right Tweeter - Use Combined R16 B484 20 Blue/Green Shared with R160, not needed for BitOne
    Rear Right Midrange + x R106 T32h 9 Red/Gray
    Rear Right Midrange - x R106 T32h 21 Brown/Gray
    Rear Right Midbass + CH7 + R160 T32h 4 White/Green Shared with R16, contains full signal
    Rear Right Midbass - CH7 - R160 T32h 16 Blue/Green Shared with R16, contains full signal
    Subwoofer + CH8 + R157 T32h 25 White/Yellow
    Subwoofer - CH8 - R157 T32h 30 Blue/Yellow
    Man does the table function suck! Next time I'm posting a PDF.....
    If my theory and wiring chart is correct, you should be able to use this to wire up other processors (MS8) or LOC for your subwoofer, etc. You will want to use the "full" or "combined" signals wherever possible. After looking at the B&O schematic, it looks like there are things like microphone and telephone mute that go through the amp, so it doesn't look like it's a great idea to remove the amp completely in favor of a device like the Mobridge (though straight digital to digital sounds AWESOME!)
    I realize I'm not 100% experienced in the Audi realm of car audio yet, so please forgive me if I've made an error above. I won't be able to confirm anything until I actually begin install. However, I hope to be building an awesome SQ install that gets plenty loud.
    I will be using the factory locations for most speakers in the car and I will be removing the additional midranges and tweeters in the rear. I will be utilizing the rear midbass locations for some full range 6", removing the stock B&O sub to replace with some sort of sub stage, replacing the front midbasses with 7 or 8" speakers (based on depth), 1" tweets in the sails, 3" midrange on dash, and a 3" midrange in center. As I'm out of speaker outputs for the rear speakers, I might just run them from the factory amp, or run an Audio Authority 3xs to split up the front stage further and give me a couple more outputs for those rears.
    Confused yet?
    Stay tuned....The B8 would be the second OEM integrated install I've done, so we'll see where it takes me.
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Jan 28 2013
    Sounds like you might have an issue. But, you may want to check which sound focus "profile" you are set too. There are different setting like: Driver, Front, Rear and All. Each can change the sound pretty dramatically.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by Lamprey View Post
    Was going to say the same.
    2021 Audi S4, P34 Intake
