Results 1 to 20 of 20
    Oct 27 2015
    Latvia
    Eurocode sway bars setup
    Hi,
    S6/S7 owners, what setup you are running with Eurocode sway bars, front and rear? Is the softer setup of eurocode harder than original?
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    As recommended by EC: soft up front, hard in rear. The difference in handling/body roll is significant (great mod!). Not exactly sure how you're defining 'harder', so not sure how to answer that.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I ran soft front, stiff rear. Used the bars and links...couldn't have been happier. I was in SoCal so I did not use the dust boots, If I was in an area with weather, I would have used the boots and packed them with grease.
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    Quote Originally Posted by S4Per View Post
    As recommended by EC: soft up front, hard in rear. The difference in handling/body roll is significant (great mod!). .
    Huge plus one. Great mod
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Apr 11 2014
    colorado
    How about hearing from some rs7 owners who have installed the bars
    Oct 27 2015
    Latvia
    Wondering Why Audi does not make sways like this in first place, do they really want their cars to have massive body roll?
    Veteran Member Four Rings SharkNardo's Avatar
    Mar 16 2007
    Richmond, VA
    I'm getting ready to install the EC sways and end links in a few weeks. I'm also doing the top and bottom diff mounts from EC as well and a Unitronic Stage 1+.
    Does anyone have experience with the EC diff mounts? Do they make a noticeable difference in decreasing driveline slop? I did the 034 trans mount and I think it made a noticeable difference, mostly in S mode.
    Also considering the Alu Kreuz as well. Feedback I've gotten so far is that the difference is negligible in terms of improved steering response. Any feedback on the AK?
    I'm considering tracking the car and I'd like to set up the steering, handling, driveline stability, and power ideally. I may move to coilovers and Stage 2 down the road.
    Other Cars
    2018 Golf R
    2019 Golf Alltrack SEL
    2016 Jetta GLI
    Previous Cars
    2019 RS5 Sportback
    1998 Porsche 993
    2015 A6 3.0T
    2004 A6 4.2
    1999 A6 2.8
    Oct 27 2015
    Latvia
    Quote Originally Posted by 4.2 Dreamer View Post
    I think you should do stage 2 with pulley, it makes lot of difference to this car.
    I'm also considering alu kreus and new-wider wheels, with spacers the car handles much worser, thinking of removing them.
    Established Member Two Rings VPRS7's Avatar
    Nov 01 2014
    Quote Originally Posted by noproblemjoe View Post
    Same setup as above (soft front, stiff rear). I don't have the end links, as they were out of stock when I did the suspension install (KW HAS + Eurocode sways).
    Love it!
    2014 Audi RS7: Daytona Gray / Unitronic Stage 1+ Tune / 21" Corse Werks Agio Monoblock w Michelin PSS / DRC / KW H.A.S. / Eurocode Sways / AWE S-Flo Intake / Sport Exhaust / Carbon Inlay / B&O / VAG mods
    Former: 2012 C63 AMG Coupe, 2012 M3, 2008 M3 Sedan, 2004 M3, 1998 M3 (track-prep), 1998 M3, 1991 M5....
    Senior Member Two Rings Mr. Three's Avatar
    Nov 27 2012
    Aptos, California
    I second the question on the diff mounts: noticeable? I also want to reinforce the notion that you have to get the Eurocode Sways...they make a huge difference in the agility and stability of the car. Don't hesitate.
    2023 S3 Daytona PP, S Sport, EMD Springs, EMD 10mm, 034 insert
    Cars of the past: 83 A1 GTI / 83 Callaway stage 2 A1 GTI / 86 951 Turbo Porsche Autothority K-27 / 98 Dinan M3 / 95 3.2 OBD1 M3 / 02 E39 M5 / 88 E28 528i / 08 RS4 / 13 S5 / 14 S5 / 15 S5 GIAC Stage 2 / 16 APR tuned S6 /
    01 996 911 Turbo ByDesign Stage 4 / 2018 S4 DT Tuning and EMD suspension / 2019 Etron Quattro / 21 S4 DT Tuning EMD susp /
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Tampa, FL
    So I'm installing now and I don't see what makes them stiffer vs softer I assume it's which hole on the sways that you use...also any advice on how to install the dust boots?
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Quote Originally Posted by fatherdeath View Post
    Inner is stiffer
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
    Jul 20 2016
    Tampa, FL
    Perfect Thank you I didnt see that in the instructions ...also i found out a great way of getting the boots on that took little effort...also packed them with "grease" Im using Frog Lube paste
    SOLD:2017 S6 Mythos Black Arras Red interior all the Wayne tech gadgets, RocEuro, EPL stage 1, 15mm front/20mm rear spacers, Eurocode Sways, end links, billet mounts ALL
    American enjoying the autobahn
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Enjoy
    Sep 04 2011
    Central NJ
    Care to share how you did it? My installation is scheduled for Thursday.
    Sep 10 2015
    VA
    I could not get the rears on at all with the end links. Ended up cutting them at the sleeve and they worked great. The fronts were very easy to get on.
    Jul 20 2016
    Tampa, FL
    I used 2 long spoon handles going in the bottom out the sides then leveraged around the "ball" of the links and then it got around fairly easy
    Sep 04 2011
    Central NJ
    Thanks for sharing. When I first got started yesterday I thought the end links would never fit through the small hole in the rubber boots. Using your two spoons trick I was able to stretch the hole wide enough to get the job done.
    2016 Audi S6 Prestige
    2015 Audi Q7 S line Prestige
    Jul 20 2016
    Tampa, FL
    yeah im glad it helped i have no idea if there is a real tool to help this..because its not easy
    Veteran Member Three Rings tenspeed's Avatar
    Dec 13 2011
    Honeoye NY
    Speculums are made in many sizes but spoons work and are readily available.
    2012 A7 3.0T Prestige, Ibis white/Nougat/Ash, 20" Sport, ACC, LED, HUD, Ferrada FR2 wheels, AWE Touring exhaust, Adam's Drag II rotors, BlackVue dash cams
    As I've grown older, I've learned that pleasing everyone is impossible,
    but pissing everyone off is a piece of cake
