Results 1 to 8 of 8
    Deactivated Two Rings shadyreddy's Avatar
    May 29 2014
    Chicago/IL
    45k Service today - What all do I need to be checking ?
    Hi guys!
    My 2014 S4 is going in for its 45k service and I was wondering if I need to get them to check something since it is going to be off the warranty period after this. I did put in a request to get those annoying rattles fixed and my blown headlight bulb (for some reason it turns on and then after a few mins it goes dark =\) .. What else should i call out for the service folks to check out?
    Senior Member Three Rings sc117's Avatar
    May 11 2015
    2015 Audi SQ5
    NOVA
    Which annoying rattles?
    Senior Member Two Rings mavz's Avatar
    Apr 06 2015
    Quote Originally Posted by shadyreddy View Post
    Hi guys!
    Just confirm whether or not they are going to charge to you fix those rattles. When I asked my dealership they said they would charge (I was doing my 25k service at the time) so I was like nope nope nope.
    Gone: 2013 Estoril S4
    APR - AWE - Vorsteiner - Continental - ECS - Akebono - JHM
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Have them check the battery. I had mine replaced with Audicare
    Have them check the weather strips around the doors. Those are known to "detach" and they will re-affix under warranty.
    If you have any concerns about any issues bring it up and have them check/document those at this service so that if you have issues down the road they were already identified while under warranty. Other than that don't worry too much. Mine's been bullet proof since day 1 and I've been out of warranty a year now with no issues... wear and tear things will never be covered anyways...
    BTW - I just had my 35k service done yesterday. I had them do a transmission fluid/oil replacement as well as rear diff fluid/oil replacement... plus lube the bearing in my short shifter. Not sure why they have those as lifetime fluids?! The TV rear diff in the S4 is the same as the RS5 and those come with an oil replacement schedule... why not the S4?!
    Jul 10 2015
    Quote Originally Posted by MrFunk View Post
    Good to know. Did you notice anything different after you had the rear diff fluid changed? Car feel better? Probably can't really tell but I'm curious lol.
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    They changed my brake fluid for free at 45k
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Apr 04 2012
    MSP
    Quote Originally Posted by bizzy View Post
    No not really. I only have 35k on it so wasnt like i was at 100k and replaced it. My friend did his at 50k and felt it shifted more smoothly (did his transmission fluid also)...
    Sent from my SM-G925P using Tapatalk
    Jul 10 2015
    Hm, strange that Audi doesn't have this as part of the maintenance schedule..
