I am parting out a 1998 AEB fully built A4. Most all the parts are pulled out. I will be adding more things for sale coming up. The engine on this car was rebuilt 10K miles ago. Before you ask, NO I am not selling the S4 bumper. I am going to be adding more parts for sale so keep an eye for things. Right now the engine is not pulled, but I am working on that. I would prefer local pickup in Baltimore for heavy items like the engine and the transmission. I am putting the proceeds of this sale into my 2001 A4 5 spd Avant soon to be 6758 EFR from PAGPARTS.
Tune and fueling system 034 AEB fueling solution. Includes 034 POS elim wiring kit for 2.0l Coil packs, coilpacks, Slot MAF, 550 cc EV14 injectors, and tuned ECU. Plug and play AEB solution for a 28 series turbo. $1500
Built engine bored to 81.5mm Wiseco pistons, IE rods, new rod/main bearings, polished crank, balanced intermediate shaft, ARP main cap studs, ARP cylinder head studs, rebuilt cylinder head. Compression test done all cyliners between 160 and 140 PSI. $2000
2871r Elimnator with a fresh CHRA (10K), with high flow ATP manifold, test pipe and 3. inch intake, $1500
Apikol side intercooler SMIC with hose kit. $450
Headlights – 1998 after market headlights with Morimoto xenon 55watt ballast kit. $300
IE intake large port 60mm stock intake AEB $550 Selling this depends if someone is going to buy my 630 uni tune so I can shift to meistro.
630 UNI tune with 630cc injectors for a 2001 AWM $600
I have tons of other parts to add to this, so please check back later
