Results 1 to 2 of 2
    Aug 12 2012
    Huntington Beach CA
    2001.5 B5 S4 Nogaro - manual - No Longer Available
    Price drop, help me buy an air cooled 911. Updated CL link at the bottom.
    Low mileage, stock audi b5 S4, 6 speed manual, in excellent condition for sale. Just passed smog check. 2 owner car with perfect car fax no accidents, clean title in my hand ready to sign. Nogaro blue on black interior, cold weather package.
    Car is basically stock except for a few upgrades, mostly for reliability. Here is a list of replacements/maintenance
    Timing belt & water pump (done at 60k miles)
    APR stage 1 ECU with stock 91, 93 and valet tunes (passed smog in 91 tune)
    New diff axle seals and fluid
    Brand new valve cover gaskets and cam tensioner seals
    Perfect center LCD screen with OEM replacement by speedo solutions
    710N diverter valves
    New ICM, Coil Packs, Spark plugs
    Silicone Throttle Body Boot
    Full ECS silicone boost hose kit
    Both rear wheel bearings, Passenger front wheel bearing
    Driver and Passenger outer tie rod ends
    Passenger side outer CV boot
    ECS drilled and slotted geomet brake rotor kit front and rear
    All 4 door speakers and both rear deck speakers replaced with infinity reference speakers (sounds awesome!)
    Car is shown with 18X8.5ET35 VMR V705 hyper silver wheels with bridgestone potenza S04 pole position tires in 235/40/18. Tires have less than 2000 miles on them. I also have the stock 17" Avus wheels mounted with Nokian Hakaapoliita R2 snow tires for sale (+$500). Tires have about 50% tread left, used for 2 seasons. Also have the Ross tech VAG-com hex-can-usb cable for sale (+$300)
    Known flaws:
    headliner beginning to sag in back
    small section of clear coat pealing on roof - see pictures
    Seam on driver side seat bolster separating
    One bent wheel on passenger front side. Still holds air, no vibrations, see pictures. Can be fixed, or new wheel is $200.
    One missing wheel center cap.
    Link to more pictures: http://orangecounty.craigslist.org/cto/5615412032.html
    List Date: 4/21/2016
    For more info, click here to view the original listing: 2001.5 B5 S4 Nogaro - manual
    This item is no longer available.
    Aug 12 2012
    Huntington Beach CA
    sold thanks!
