Low mileage, stock audi b5 S4, 6 speed manual, in excellent condition for sale. Located in Huntington Beach CA, just passed smog check. 2 owner car with perfect car fax no accidents, clean title in my hand ready to sign. Nogaro blue on black interior, cold weather package.
Car is basically stock except for a few upgrades, mostly for reliability. Here is a list of replacements/maintenance
Timing belt & water pump (done at 60k miles)
APR stage 1 ECU with stock 91, 93 and valet tunes (passed smog in 91 tune)
New diff axle seals and fluid
Brand new valve cover gaskets and cam tensioner seals
Perfect center LCD screen with OEM replacement by speedo solutions
710N diverter valves
New ICM, Coil Packs, Spark plugs
Silicone Throttle Body Boot
Full ECS silicone boost hose kit
Both rear wheel bearings, Passenger front wheel bearing
Driver and Passenger outer tie rod ends
Passenger side outer CV boot
ECS drilled and slotted geomet brake rotor kit front and rear
All 4 door speakers and both rear deck speakers replaced with infinity reference speakers (sounds awesome!)
Car is shown with 18X8.5ET35 VMR V705 hyper silver wheels with bridgestone potenza S04 pole position tires in 235/40/18. Tires have less than 2000 miles on them. I also have the stock 17" Avus wheels mounted with Nokian Hakaapoliita R2 snow tires for sale (+$500). Tires have about 50% tread left, used for 2 seasons. Also have the Ross tech VAG-com hex-can-usb cable for sale (+$300)
Known flaws:
headliner beginning to sag in back
small section of clear coat pealing on roof - see pictures
Seam on driver side seat bolster separating
One bent wheel on passenger front side. Still holds air, no vibrations, see pictures. Can be fixed, or new wheel is $200.
One missing wheel center cap.
Asking $8500
Link to more pictures: http://orangecounty.craigslist.org/cto/5520396846.html
S4_HiRes 064.jpgS4_HiRes 066.jpgS4_HiRes 008_2.jpgS4_HiRes 020.jpgS4_HiRes 029.jpg
https://www.panjo.com/buy/2001-5-b5-...y-stock-276838
