Results 1 to 3 of 3
    May 31 2015
    Louisville - Ky
    Trouble starting when it's hot
    I have noticed that in particularly hot days, my car has more trouble starting after sitting in the sun all day - it turns over more times before firing up. Anyone have a thought as to the cause? Battery has tested fine...
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    some people with a bad Crank position sensor had similar symptoms, except the car wouldn't start at all when hot
    Junior Member Two Rings
    Jul 04 2010
    Boise Idaho
    Quote Originally Posted by jakeoboy67 View Post
    Could be the fuel pumps under the seat as I had a similar situation and pulled the bach seat out and just tapped on the pumps and seemed to work
