Results 1 to 8 of 8
    Senior Member Three Rings Cousinphil's Avatar
    Jan 29 2015
    1954 Ford Jubilee Tractor,1986 Ford Diesel Tractor, 2006 GMC One Ton Dump, 1986 Nissan Flatbed Truck
    East Blue Hill Maine
    New Konis = Rough ride!
    Most nights up here in this part of Maine temperatures are still below freezing but in the daytime the mercury has soared up into the low fifties and the sun is shining and people are out walking around and for me it has been time to get the Avant out of winter mothballs and get her back on the road. She started instantly and is running flawlessly.
    The stock shocks were definitely OK and the ride was smooth and the handling was top flight. But in my quest for the ultimate ride to get me around my piano tuning route, I ordered four new Koni SFD shocks and had them installed a few days ago. I got the car back and got behind the wheel and immediately noticed that these shocks are quite firm. In fact more than just firm. Harsh, rattle your bones rough. I took my wife dancing on Saturday night and we took the back road and she didn’t like it at all. She suggested we take the smooth high road going home. I wondered if I had made a horrible mistake with the Konis. I considered calling the garage and having them pull the stock shocks out of the dumpster.
    As I understand it, the Frequency Selective Dampening allows the shock to make quick small movements with minimal dampening but the shock will clamp down for any kind of deep movement, such as a body roll.
    But then I remembered that on the bill it had said that they had checked the tire pressure. Maybe they had overinflated the tires. Sure enough, the fronts were at 32 cold and one rear was 33 and the other was 34. Sheeit! I lowered them all to 30 and what a difference! The harshness went away. The shocks are definitely firmer than the old ones but not objectionable. No noticeable body roll at all. The car is handling beautifully. Now I just need a new clutch and maybe some motor mounts. And an APR tune.
    2004 A4 Avant 1.8T 6 Speed 120,000 miles Summer
    2005 A4 Avant 3.0 Tiptronic 80,000 miles Spring and Fall
    2005 A4 Avant 1.8T Tiptronic 105,000 miles Winter Tires
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    Wow really that big a difference just from 4 or 5 pounds..? Have only seen a couple instances of discontent after switching to the FSDs. Thinking about making that switch myself.
    I can certainly understand wanting as smooth a ride as possible but do you think the lower tire pressure is worth it? You know vs. the safety concerns/risks of under inflation?
    Jan 29 2015
    Actually, 30 lbs, front and rear, is what is recommended. I'm running Michelin 215 55 R 16s. I imagine that the Koni shocks will eventually loosen up a bit.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Yes, 4-5 psi can make a difference in ride comfort. It also depends on the tires, their load rating, compound etc.
    Did you also replace the shock mounts on all corners? Worn mounts will contribute to "trashy" ride as old and collapsed rubber mounts will transfer any noise/vibration into the chassis.
    I love my FSDs!
    Aug 26 2005
    Koni FSD dampers are definitely not firm riding.
    Who did the installation of the Koni FSDs? A crucial requirement of the install procedure, the suspension pivots points must only be torqued with the suspension at the loaded ride height position. If the suspension was torqued with the suspension at the fully extended unloaded position, the resulting ride qualities will be harsh and stiff, due to the excessive wind up in the rubber suspension pivot bushings.
    If the suspension pivots were torqued at the unloaded extended position, the bushings will be ruined due to the excessive twist up in the rubber bushings.
    I recommend you discuss the procedure used to torque the suspension with the installation shop. The suspension may need to be first loosened then retorqued at the loaded ride height.
    Vorsprung durch Technik
    Aug 20 2012
    Mesa, Az
    Quote Originally Posted by Cousinphil View Post
    I see. I assumed you were on the USP 18s.
    I certainly would agree the suspension pivot points would need to be re-checked and torqued at static ride height level.
    Nov 10 2015
    Sudbury, ON
    This was my guess reading the OP's first post.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Jan 29 2015
    [QUOTE=diagnosticator;11568758]Koni FSD dampers are definitely not firm riding.
    Who did the installation of the Koni FSDs? A crucial requirement of the install procedure, the suspension pivots points must only be torqued with the suspension at the loaded ride height position. If the suspension was torqued with the suspension at the fully extended unloaded position, the resulting ride qualities will be harsh and stiff, due to the excessive wind up in the rubber suspension pivot bushings[QUOTE]
    ####The installation was done by a professional auto repair shop in Ellsworth, Maine. Today I went back and talked to them about the shocks and they said the Diagnosticator is absolutely right about the installation process and they reassured me that that was exactly how they had done it. I have been driving on these brand new FSD shocks for a week now and they are definitely loosening up. Having the tire pressure a few pounds above 30 contributed to a harsh ride but that wasn't the whole story. After I had adjusted the tire pressure the shocks were still much firmer than the old stock shocks which were by no means worn out. But I've been tearing up the roads getting around to pianos all over the map, and on some bumpy roads at that. And the ride is definitely getting smoother. The way they are now, I have no complaint with them. In fact, I've thrown the car into some long sweeping curves just to see how much body roll there was and the car feels great. Stable as can be. ####
