Results 1 to 12 of 12
    Established Member Two Rings PurdueB8A4's Avatar
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    Exclamation The dreaded P0420...
    Hi all,
    Just driving home from work when I got a check engine light-- hooked up the diagnostic & found it was the P0420 (catalyst system below efficiency bank 1).
    Car has ~95k miles with only ~35k miles on a new long block put in by Audi. I will say it seems like my fuel gage is going down a lot faster than normal... I used to get close to 400 miles from a tank & now I'm getting around 350ish. I use Shell V-Power (93 octane) Does this seem like it would be a spark plug, 02 sensor, or cat converter issue? No weird rotten egg smells, the cat looks normal, isn't glowing or anything.
    Just trying to trouble shoot this before replacing a bunch of parts that possibly don't need to be replaced. Is there a sure fire way to tell which component is causing the problem?
    Also, has anyone had any luck with an additive such as Cataclean? Someone recommended running a bottle through the tank when down to 1/4 tank.
    Thanks in advance!
    2009 Quartz Gray Metallic Audi A4 Prestige
    aFe | Akebono | APR
    Veteran Member Three Rings mr_milo's Avatar
    Oct 18 2013
    SF Bay Area, CA
    P0420..... sadly appropriate for today. Hope you get it sorted out.
    2014 A4 P+ 2.0TQMS
    2011 BMW 328i Convertible 6 Spd Manual - SOLD
    1999.5 A4 1.8TQMS - SOLD
    1986 4000CS Quattro 5 Spd Manual - SOLD
    Save the Manuals!
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    Quote Originally Posted by mr_milo View Post
    Haha, no kidding... My car is playing a nasty joke on me.
    aFe | Akebono | APR
    Jun 26 2009
    Bremerton WA
    Do you just have a code reader or can it read sensor data? It may help in narrowing it down. Front O2 sensor lambda should be near 1 at idle. Fuel trims should be single digits the closer to 0 the better. These numbers help establish that everything it running properly. Then look at the rear O2 sensor voltage output. Normal is near .45 volts(theoretical as I never checked mine with the stock cat),mine reads .6 with a High Flow Cat installed.
    VMR 710's, APR software, Eurocode HFC
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    Quote Originally Posted by van462 View Post
    Awesome, I'll see if I can grab a vag-com & test it out. I'm
    Hoping it is just an O2 sensor... Fuel economy has been getting pretty bad. Either that or spark plugs..
    aFe | Akebono | APR
    Junior Member Two Rings
    Mar 15 2016
    Chicago
    Not sure if it's going to be relevant but I used Cataclean on my BMW 530i w/ p0420/430 codes and it didn't do anything, YMMV. Did two cans of it in succession.
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    it cant hurt to change out the plugs with new ones. I got my plugs for $13CDN from carquest which was half of what dealer wanted. Easy DIY
    I have the same P0420, I bought a used cat and I will be swapping myself
    It gets damaged from either oil overfill, possibly severe oil burning engine, or leaky injectors which are a known problem for our cars covered by extended warranty for that but you'd know if you had that.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    You need a new cat, don't waste your money on anything else.....i believe Federal Law states these must last 8 years i think (check your manual), i would not clear the code, instead take it in to your local dealer, you should be able to get a free one.
    Stage 1 more than you RS3
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    I didn't clear the code-- the CEL did disappear however... Weird. I do have an appointment with my local dealer, maybe they can shed some light-- I'm thinking O2 sensor issues.
    aFe | Akebono | APR
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    Quote Originally Posted by o1turbo30v View Post
    I also saw this while searching, but isn't the federal law 8 yr/80k miles, whichever comes first? I just cracked 95k, so I doubt I'd qualify for a "free" converter unfortunately.
    aFe | Akebono | APR
    Mar 04 2016
    2015 Nissan Rogue
    Indianapolis
    Can anyone confirm that replacing the stock cat w/ a high-flow unit will definitively cause a check engine light? Wanting to weigh my options-- dealer "confirmed" that the p0420 was due to the cat needing to be replaced -- at $1800 parts & labor (yeah, right).
    aFe | Akebono | APR
    Established Member Two Rings punkalex1's Avatar
    Oct 26 2015
    Orange County CA
    i just installed a 034 motorsports HFC without an 02 spacer and got a CEL after 50 miles. so yea definite CEL
