File this under "I was bored".
Cold winter weather plus short commutes netted me this clogging up the factory PCV valve:
Remembering I had a spare air/oil separator laying around the garage I decided to install it. The idea being that it would be easier to clean and wouldn't clog as easily. All it took was a couple of feet of 3/4" hose and a 3/4" splice. The new air/oil separator is installed inline and upstream of the factory PCV valve. The brace from the coolant expansion tank to the ABS module makes a sturdy place to mount the new one.
Now that warmer weather has returned it also seems to have helped with the mild detonation issue I was having under moderate to hard acceleration. I've had detonation on forced induction engines before but this is the first time I've had it caused by blowby on a NA engine. Part of me wants to do a compression/leakdown test but then I remember I'm lazy.
