Results 1 to 12 of 12
    Dec 09 2007
    Bowling Green, KY
    Charging System Failure/ No Power Steering
    Hello and Good Morning,
    Yesterday after work as I was about to pull into my garage I got the "charging system failure" light on the dash. I turned the car off and started it again and there was no issue. But they when I turned the wheel my power steering wasnt working. My 2010 S4 DSG has 99800 miles on it (I must be one of the high mileage members) and havent had any issues up til now.
    Curious if anyone else has dealt with this, Seeing as how its charging system and lack of power steering (I have hydraulic) leads me to believe it must be an issue with the accessories belt or tensioner.
    I will let you know when I have more information, and will add photos, but I hope to see if anyone else had seen this.
    EDIT****
    Crank pulley seperated. Im not interested in a $400.00 Al replacement, so I modelled my own and am waiting on a quote :)
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Is your battery still original from 2010?
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Bet your crank pulley failed. It will cause the belts not to spin. Upgrade to a JHM one.
    You can push and pull the pulley forward to verify it.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Dec 09 2007
    Bowling Green, KY
    Yes the battery is the original. Ill look for separation on the crank pulley. Thanks for the tip!
    Dec 09 2007
    Bowling Green, KY
    Quote Originally Posted by infinkc View Post
    You were right infinkc. Got the car in service mode and pulled off the serp belt and the crank pulley is separated and the outer part free spins. I'm just glad the belt didn't explode. I'm a bit peeved jhm's pulley is $400.00 plus.... I'm an engineer by trade and the r&d for one of these is pretty minimal. I think I'll make my own model and have it cnc'd at work for much less. Titanium crank pulley anyone? ;) lol
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by Duhafnusa4 View Post
    400 is not bad for theirs if you consider the oem one is the same price. You might msg s4matty to see if he will send you his cad files.
    Dec 09 2007
    Bowling Green, KY
    Thanks man Ill send him a pm!
    Dec 09 2007
    Bowling Green, KY
    Hey so update, Ive gotten all the pertinent date from the crank pulley and have modelled up an Al replacement.
    here is what I have:
    I am waiting on a quote for one to be machined out now.
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    I hope the s4 is not your daily driver if your waiting all this time to build a new crank pulley.
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Dec 09 2007
    Bowling Green, KY
    Quote Originally Posted by B8 S4 View Post
    It usually is my DD but i have other cars....
    I hope your comment wasnt just a waste of time
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    There are cases where an aluminum aftermarket crank pulley (for the 2.0 TSI) would wear at the point where the seal rides, and the engine developed an oil leak.
    Also, there is a thread in the S4 forum discussing the potential risks of replacing the factory damped pulley with a solid undamped aftermarket pulley.
    Dec 09 2007
    Bowling Green, KY
    You pose good points, and an inertial dampner does have a lot of benefits. I am waiting on a quote from ati for a damper solution as well.
