Results 1 to 2 of 2
    Junior Member Two Rings TheAlphadog's Avatar
    Nov 03 2015
    Another car
    Cedar Rapids, IA
    Question 2011 A6 C6 current ECU/TCU revisions
    I bought a genuine Ross-Tech VAG-COM Hex+Can dongle from a coworker yesterday. I used the latest VCDS release to generate a report and am happy that all module statuses reported as OK. Although my transmission, shifting though gears 1 to 3, has been smoothed out with merely a battery disconnect (for 2 hours) and reconnect, I still wonder if there are later ECU/TCU updates that will make any further fuel economy gains, shifting smoothness, etc.
    Two questions:
    1) Engine reports a H07 revision. Auto Trans reports a H05 revision. Are there later updates that produce any noticeable/observable changes to the driver that are worth the cost for the out-of-warranty trip to the dealer?
    2) There are ways to modify the TCU to disable DSP. My code, 0000002, shows the DSP mode as enabled. According to other forum posts on the topic, changing to 0000012 should be the code to disable the DSP. I highly dislike the "D" mode feel and favor "S" and "M" modes but sometimes opt for the fuel economy and convenience of "D" for start and stop traffic. Wondering if the coding change may help at all? I plan to do this mod anyway within the next few days, but would like any input you all may have.
    Here is a snippet from my VCDS log:
    Chassis Type: FB (4F0)
    Mileage: 101540km-63094miles
    Address 01: Engine (CCA) Labels: None
    Part No SW: 4F1 910 551 D HW: 4F1 907 551
    Component: 3.0l V6 TFSI 0030
    Revision: --H07--- Serial number:
    Coding: 0105000A190F0120
    Shop #: WSC 02325 785 00200
    VCID: 24470955E757AD1E3A-8070
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4F9 910 156 A HW: 09L 927 156 C
    Component: AG6 09L 3,0TFSI USA 0020
    Revision: --H05--- Serial number: 4575691
    Coding: 0000002
    VCID: 2A5BE76D85737B6E00-807E
    Nov 03 2015
    Another car
    Cedar Rapids, IA
    Quick update: I cannot get any transmission coding value to stick other than 0000002.
