Results 1 to 6 of 6
    Aug 14 2015
    Pa
    Sunroof help!!!!!
    Well I noticed that when I try and open the vent on my sunroof (pushing up on the button) it sometimes doesn't work, or it will open and then close by itself. And when I try to open the sunroof the whole way I have to turn the knob click by click, because if I try to turn it all the way in one motion, it will either not open or just stop opening. I have to do the same thing when trying to close it also, just click by click till it finally decides to close.
    So far ive swapped the motor from my parts car and also the whole switch and nothing has changed, someone please help me as my ac doesn't work at the moment either (ac pump exploded )
    2003 a4 Quattro 1.8t 5mt
    Dec 30 2014
    Nogaro 2000 S4 6-Speed, Ebony Pearl 2002 A4 5-Speed
    South Carolina
    The switch is going bad, very common failure. You can replace it or repair it using a diy found on audizine. Google phantom sunroof repair and you should find it. I'm to lazy to find it for you. :)
    Aug 14 2015
    Pa
    alright thanks for the help!
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Quote Originally Posted by Forsythe003 View Post
    http://www.a4mods.com/index.php?page...s/sunroof.html
    This should help
    Established Member Two Rings RainJer's Avatar
    Jun 27 2014
    Audi Q7 TDI - 996 C2 Cabriolet
    San Diego
    Quote Originally Posted by lyates1987 View Post
    Thank you
    996 C2 Cabriolet - 2014 Q7 TDI - 2002 A4 Avant
    BPCDubsť
    Sep 17 2014
    Lakeway
    Quote Originally Posted by RainJer View Post
    Thank you
    Fer Shizzle
