Results 1 to 6 of 6
    Jan 07 2011
    2013 C300 4Matic
    Issues with my airlift autopilot v2
    2 compressors
    3/8 lines
    4 gallon tank
    this is a long shot, as I know issues is hard to diagnose without having someone check the system physically, but I thought Id get some ideas here if anyone has any
    during the winter time last year int he BRUTAL cold ( talking about 20 degrees with a real feel of -10 ), while driving I heard a pop noise in the trunk ( that's where my setup is ). went to check it and everything seemed fine
    as days/weeks/months goes by, I noticed that my rise to start was not working as it used to. I usually air out while I park, and once I start the car, it automatically lifts to 100 psi. right now, it just sits there for a few minutes before it goes up. I check the remote, and its because I start up at around 20psi in the tank, when it used to start at around 100. so I believe I have a slow leak somewhere. now I have to sit and wait for the tank to fill up anywhere near 125 before I can air up to 100psi and start moving ( my garage requires it ). I have already checked all the hoses with a spray bottle/soapy water and all the lines look good. I did the balloon test with both compressors and the water traps under my car, and no air leaking there.
    anyone have any idea where else I can check before bringing it in? visually there is no problems and all lines are 100% intact.
    and yes I know I can just not air out before I park so I can start up and move, but I just want to get it back the way it was
    thanks in advance
    Present:
    2009 Audi S5 Phantom Black
    IG: bknewtype
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    I'll see if my buddy can answer. He's our local Airlift guru.
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Jan 07 2011
    2013 C300 4Matic
    Quote Originally Posted by jokingjimmy View Post
    Appreciate it! I know its hard to diagnosis without seeing everything , but my buddy who installed my air did a visual and hose check everywhere and no issues :(
    Really hope i don't have to take it apart to find the issue
    Present:
    IG: bknewtype
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    Could it be a leaky check valve?
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Oct 20 2014
    Pittsburgh, PA
    I sent him the link. Now if he'll answer is a whole other thing lol. You would be amazed at the hack jobs he's seen, so I figure he'd be able to take the best guess...
    Previous:
    Jan 07 2011
    2013 C300 4Matic
    Thanks jimmy!
    Present:
    IG: bknewtype
