Results 1 to 40 of 60
    Veteran Member Three Rings notn41's Avatar
    Jul 09 2013
    2012 V Rod Night Rod Special, 2009 GSXR 1000
    Las Vegas
    S7 to FULL RS7 conversion estimated price?
    Anyone who is very familiar with the engine, trans, ecu etc. What would it take to make an s7 into an rs7. Engine compression ratio, turbos, etc. maybe trans too.
    Not interested in external bodywork, just performance.
    I know nothing about this but I was curious. I know the compression ratio is lower on rs7(full internal different or just lower compression difference only?), larger turbos, different cooler, different trans.
    2013 S7 Phantom Black
    Options:Innovation Package, Comfort Seats, Radar Assist
    Interior Mods: Atlas Carbon Inlays, Full leather/alcantara red stitch interior, Full led interior lights, facelift sweeping tail lights
    Exterior Mods: H&R Lowering module, 15mm spacers, Black OEM RS4 wheels 20", Stinger VIP, Milltek Valvesonic High flow catted TBE
    Senior Member Three Rings JoeCaMotto's Avatar
    May 06 2014
    Chitown
    I think it would be cheaper to just upgrade to RS7 then to try and covert S7 into RS7. Just my .02
    14 White S7 Loaded
    14 HD white demin V-rod muscle
    10 White Ford Raptor 6.2 Loaded
    09 Red GT-R sold
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    For context: a new engine looks to be around $37k from Audi based on a recent thread on here.
    Haven't looked into if the tranny would actually fit - I highly doubt it would. Even if it did, I'm sure those aren't going for less than $10k.
    Trivia might be a reason to explore the full answer here, but economics / practicality stop you pretty quickly.
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    What did inspire you to have this idea? This project is in no way gonna be cheaper than just walk in to dealership's door and trade in for RS7.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Account Terminated Two Rings
    Dec 10 2013
    Quote Originally Posted by S4Per View Post
    Just because a new RS7 engine may cost tens of thousands new from the dealer doesn't necessarily mean it will cost anywhere near that to convert an S7 engine to RS7 specs. The blocks are identical.
    While I personally wouldn't go through the trouble or cost of touching the bottom end because I feel the differences are trivial, it's not out of the realm of possibilities to pull the engine, buy RS7 pistons, crankshaft, cams, exhaust valves and hardware and drop it off at a local machine shop with a good reputation.
    Why wouldn't the tranny fit? The S7 and RS7 share identical chassis.
    If you took the time to actually look up the price of the RS7 transmission you'd see it's significantly less than $10K. Why make statements like "I'm sure those aren't going for less than $10k" when you really don't have a clue how much it costs? It's this kind of misinformation that's dangerous since people accept it as fact and often act on it.
    Quote Originally Posted by VeryBadman View Post
    That's not necessarily true. It all depends on how far you want to take the conversion. Look at TurtleHaste. He upgraded only the most important bits like the RS7 turbos and inlets and based on his 1/4 mile results, he's making comparable power to a stage 1 RS7.
    Feb 17 2004
    2013 Audi S6
    My first thought when this thread came up was, "There is no way he is going to be able to resist and stay true to his word".
    Anything is possible. I put the engine price in to steer OP down a practical path where he was clearly wanting to go somewhere far beyond Turtlehaste, I.e. Read the title of the thread.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    Someone just wanted to appear smarter than anybody else like usual.
    Other: 2017 BMW X1
    Dec 10 2013
    How is correcting your misinformation not being true to my word? I made it clear today that despite no longer sharing new ideas with the forum, at the same time I'm not going anywhere.
    Putting the engine price in there with no mention or hint of an alternative plan would only steer him away from attempting a conversion in any capacity.
    I did read the forum title. Again, you can do a full conversion without paying $37K for an engine.
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    It would be nice for you to also back up your statement, With some references. other wise your just misleading people and talking out of your ass too.
    Quote Originally Posted by Vol 4.0T View Post
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Jul 09 2013
    Las Vegas
    Are engines identical minus the compression ratio and heads? Can those parts be swapped with cooling and turbos to achieve same Hp as rs7.
    And maybe leave the trans alone and pray?
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    Quote Originally Posted by notn41 View Post
    The RS block undergoes a T6 high temp bakeout/heat treatment. I don't believe the S6/7 block undergoes this process. Additionally the crankshafts are different materials between the blocks and the RS' main bearing size is 67mm (up from 65mm).
    Note 1: AFAIK, all the RS "upgrades" apply to the S8 block as well.
    Note 2: I'm sure Vol can confirm/deny all of this (no, I'm not being a smartass).
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Feb 17 2004
    2013 Audi S6
    Recycling: this is probably the most succinct and to the point summary to give OP a sense of what would be required for a FULL engine conversion.
    As stated, I don't see the point of going the route of 'full conversion', though. Get some RS7 turbos, a tune (if you have someone local you can trust, I'd go custom), and have fun knowing that you're in the neighborhood of Stage 1 RS7 tuned performance, for a lot less cash than buying an RS7.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings moosehead1's Avatar
    Dec 24 2013
    '16 Cayenne GTS
    CO Rockies
    Even if one could convert the powerplant via parts and say troll around for a slightly used tranny, and on a swag presume the cost is say $15k to do so, you'll likely double that by ground effects, trim, front end, etc. Then value the warranty. Then accept the exposure.
    Bottom line is it would take more money than sense.
    '13 S7: SRM RS7 CHRA, DS1, SRM TCU, APR HX, Screen Delete, Exhaust Mods, AWE CAI, RS7 Skirts, HR Module, Belstir+ & LI Quad, FB Wheel, 3M Tint & Bra, BBS CI-R with PSS
    Gone: '06 Touareg / '00 A6 2.7T / '94 90CS / '86 Coupe GT
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    Saw a couple 10-12k miles CPO 2015 RS7s, which means it comes with that nice Audi warranty, for $98-100k. After all the time and money that has gone into my S6 to mod and obtain closer-to-RS7 power levels, with the overarching persistent fear of breaking things due to less tolerance for strain than RS parts, I would much rather spend/finance the extra 30k for an RS7.
    So far my mods are almost $10k, so really it's a $20k difference for much more reliability and higher rated engineering in general. Hindsight is 20/20.
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Feb 17 2004
    2013 Audi S6
    One add: contrary to the assumption above, I did check the transmission price and did not supply 'misinformation'. Retail is ~$12k up here in Seattle, not counting install. $10k quoted figuring someone can get a better deal somewhere. I haven't looked at the gear ratio differences between the two, but if they're different, you might need to swap the rear diff also.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Jul 09 2013
    Las Vegas
    Fantastic video, been looking for something like this. Thank you for info.
    Jul 09 2013
    Las Vegas
    Well engine swap is out of the question. Way too many changes. What about larger turbo swap than the rs turbo swap? Maybe that would make more sense.
    Dec 20 2006
    CAN
    I can see someone doing this if the RS7 wasn't available here but that is not the situation.
    You would be spending oodles of cash to get a much less reliable vehicle with no warranty when you could just go out and trade for one likely for a lot less money and headaches.
    I'm sure it could be done, the question is why?
    emilyPay.com - Revolutionizing payment processing by making transactions simple, secure, and more reasonably priced.
    2025 RS6 Performance - Florett Silver, Blue Plus RS Design Pkg, Carbon Matte Optics Pkg, Dynamic Pkg, Black Dinamica Healiner.
    Wife - 2024 SQ8 - Chili Red
    Old Friends: 2021 RS6 Nardo Grey, 2021 Cayenne GTS, 2018 Panamera 4S ST, 2016 RS7, 2014 RS7, TT/RS, E90M3, B7RS4, B7S4
    Feb 17 2004
    2013 Audi S6
    No one has gone there - - yet.
    I'm confident that hybrids will begin to surface in the next 6-8 months, though (machine the housing and add bigger/better CHRA's).
    As noted, you can get stock RS7 performance today (straight line speed, at least) by doing the turbo swap, which also can get you close to tuned RS7 performance (documented 10.74 on Stg 3 S6 (TurtleHaste, who also did surrounding mods) vs 10.59 in tuned RS7 (Sciblades with the fastest here to date?).
    All that said, I'm not quite sure what your exact goals are at this point.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Mar 14 2012
    PHL | BOS | SEA
    TTE and Loba both have upgrades. I'm not sure how the dimensions compare to that of the RS units, but TTE has at least two options (TTE800 & TTE900). Then there is Total Race who put the GT28 setup in that blue RS7 in Europe.
    2014 S6 - SOLD
    Feb 17 2004
    2013 Audi S6
    Forgot about the Total Race (which is an RS7 for starters vs S6, though), good catch and thanks. Any idea if they moved forward to make it available to more vs that one off?
    Never forgotten:
    2002 S4 Stage 3 Tip
    Dec 10 2013
    All the 4.0T blocks are the same. The differences between the different models are in the pistons, crankshaft, cams, and valves.
    Quote Originally Posted by MileMan402 View Post
    Dec 10 2013
    Wrong again.
    https://www.audionlineparts.com/part...nent=TRANSAXLE
    Why don't you post some more misinformation?
    Mar 14 2012
    PHL | BOS | SEA
    This references the S8 block, but it shows that Audi is heat treating the high output 4.0 blocks.
    2014 S6 - SOLD
    Feb 17 2004
    2013 Audi S6
    Lol. Just stop, or please try to READ before commenting. "~$12k UP HERE IN SEATTLE, not counting install." Is that so hard to comprehend? That comes from Audi direct....ZERO misinformation.
    I moved that to $10k assuming you could find a better deal somewhere, which - great job, you found one for $7,200! You probably need to add shipping to that. So - why not say, "Hey, directionally correct, but I found a place you can actually get it for a couple grand cheaper"? This gets back to your choice about how you want to present yourself on these forums.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Dec 10 2013
    The purpose of the forum is to help people with their projects, not scare them away by quoting them inflated dealer prices which are higher than list price like you did with the transmission and engine. If you're going to go through the trouble of price the parts out, why wouldn't you look to a place that wouldn't rape the OP?
    Feb 17 2004
    2013 Audi S6
    I had the info on hand from prior (random) discussion with a friend, who happens to be a Master Tech at the largest Audi dealer in Seattle (chatting power levels and trans across C7 platform when I brought it in for service last).
    I thought OP was pretty clear about wanting a 'FULL' conversion minus body changes in his first post, hence I stopped there. You can see I volunteered more info as the question got revised.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Dec 10 2013
    Just because he wants to do a FULL conversion doesn't mean he wishes to pay through-the-nose dealer prices that are higher than full list price. It's obvious he's concerned about the cost of the swap since he's asking how much it would cost. Your posts were misleading and inaccurate and not helpful to his objectives.
    Feb 17 2004
    2013 Audi S6
    I disagree. Have a nice day.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by CanuckRS View Post
    This will make sense in 10 years for DIY guys when these cars become unreliable (in stock form due to age) and therefore inexpensive to purchase and modify.
    Jun 30 2012
    16 Lava Orange GT3 RS, 18 Nardo Grey RS3, 17 Panda Macan GTS, 91 C2 964, 16 F150 Lariat, 63 Impala
    Woodstock GA
    I thought dude was quitting the board and not helping anyone become faster.
    Because he's been such a big help with his wheel setup and all those other things.
    Feb 17 2004
    2013 Audi S6
    Nope. He redefined the word "contributing" to now mean "not starting any 'informative' threads", which is apparently not the same as chiming into other threads (my best guess at his definition, I'm sure he'll correct it shortly).
    He's now off on the 'power loss' thread trying to gather support there (completely different issue, context, circumstance) to use as proof here. The conflating of issues, statements, etc. is truly amazing.
    Never forgotten:
    2002 S4 Stage 3 Tip
    Dec 10 2013
    Yeah right. I never said I would stop correcting your misinformation. I'll continue helping people like the OP achieve their goals. I'm not going to go out of my way to start threads to share new findings, products, data, etc. that I come across along my 9 second journey.
    The other thread had nothing to do this one until you brought it up. I simply wanted to see if myself and other forum members influenced him to go the Indy route, saving him tens of thousands of dollars in the process. In other words, I'm really curious if he was actually going to shell out $40K+ to the stealership. I would never consider anything even remotely close to that but I know everyone's different.
    Apr 08 2013
    Even if the full swap to become an rs7 close was more economical up front (than selling/rading an s7 to buy an rs7), the back end loss on trying to sell a bastard car would more than make up the difference. Even for the guy who thinks he is going to keep the car forever, to me it seems more trouble than it is worth.
    MoTeC m1 powered Seadoo RXTX
    c7 s6 [email protected] gone
    997.2 TT-S [email protected] COBB/BBi
    Feb 17 2004
    2013 Audi S6
    Vol,
    Let's be done with this; it's not helping anyone. I'm going to continue to do my best of providing helpful information to people to steer them in the right direction and share what I've learned. I'm going to try and ask a couple more questions of people to clarify statements/questions so as not to assume too much. My ask/wish from you is to try to come to this forum with a spirit of "best intent", i.e. everyone is here trying to help, doing their best. If you see things you disagree with, there are great ways and not so great ways to call that out, and many times it's just our own personal filters that lead us to think one thing over another, and when someone else's perspective is gained, things can look a lot different. I think being a bit more cognizant of that will go a long ways with many on here; I know it will for myself. The statements of "I know more than everyone here combined" - - which I know was used in an emotional moment, don't help and do come through in some of your other posts. It's the 'how' of some of your posts that rubs people the wrong way and alienates them. Slight adjustments would probably lead to an entirely different experience for all of us here.
    I hope you see the sincerity in this post, and you'll help us move on from this, get a fresh start, as we're not helping anyone here. You have my promise that I'm going to do my best.
    -Per
    Never forgotten:
    2002 S4 Stage 3 Tip
    Veteran Member Four Rings SharkNardo's Avatar
    Mar 16 2007
    Richmond, VA
    This back and forth between Vol and Per has been fun to read....and thoroughly tame compared to what happens on Rennlist with the Porsche folks.....lol
    Other Cars
    2018 Golf R
    2019 Golf Alltrack SEL
    2016 Jetta GLI
    Previous Cars
    2019 RS5 Sportback
    1998 Porsche 993
    2015 A6 3.0T
    2004 A6 4.2
    1999 A6 2.8
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by 4.2 Dreamer View Post
    I can't disagree with that! It's somehow entertaining me.
    Other: 2017 BMW X1
    Mar 16 2007
    Richmond, VA
    After reading the thread Vol posted in the Chatterbox forum, I was entertained some more...and was further convinced that he would get completely DESTROYED on Rennlist. Holy flame suit Batman.
    Other Cars
    2018 Golf R
    2016 Jetta GLI
    Previous Cars
    2019 RS5 Sportback
    1998 Porsche 993
    2015 A6 3.0T
    2004 A6 4.2
    1999 A6 2.8
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    I have never owned a Porsche so I don't really know how ruthless Porsche folks can be but I have heard the rumor as well that it's very intense over there.
    Other: 2017 BMW X1
    Mar 16 2007
    Richmond, VA
    I can confirm the rumor to be true. It's a very passionate and knowledgeable group of enthusiasts that welcome new members to the fold. However, there is little patience for know-it-calls with superiority complexes that revel in starting trouble. It's a lethal cocktail that is dealt with severely and immediately. People like Vol (and some others on here and an AudiWorld Mod interestingly) would not last long.
    Other Cars
    2018 Golf R
    2016 Jetta GLI
    Previous Cars
    2019 RS5 Sportback
    1998 Porsche 993
    2015 A6 3.0T
    2004 A6 4.2
    1999 A6 2.8
