Hey fellas unfortunately i lost interest in further spending money on my S4! Ive put in a good bit of money into it and im way past my budget on it. Im selling as is for $7800 I have a Craigslist posting HERE > https://atlanta.craigslist.org/nat/cto/5519173081.html
Let me know if the link works
The posting will explain most of the major work done. This is not some sketchy sell and the turbos are in great shape. If i can find pictures when previously pulled the motor, ill send some to whoever is interested. This car is /just injectors and an 85mm maf/ away from full stage 3 away. Currently its Custom Tuned to work with the K04's/ Rear 02 Deletes/ EGT Delete/ Launch control @ 4,000 Rpm or 5,000 Cant remember. Pushing 24 PSI
I'm also running on a 400LPH Drop in fuel Kit from Project B5(runs on gas and can also run on E85 Tunes)
These are the issues:
1)vacuum leak(not sure from where, im almost sure based on research done its one of the hoses from N75 to wastegate, witch to properly fix motor needs to be taken out. Although i had a Guy from Solo-motorsports do a leak test and he ended up replacing a vacuum hose and the problem went away BUT came back after 1-2 weeks.
2) My ABS and Traction light is on NOT a mechanical issue. I bought another ECU but it doesnt have ESP(my car does) so when it was flashed and plugged in my ABS and TRACTION came/come on. As soon as I put my original ECU the lights go AWAY!
3) Re-mounted my tires because of slight but gradual wear. Because of that I'm getting vibration when driving on the Highway. When I lowered my car and did the alignment and the front two wheels where slightly off axis. Didn't want to buy adjustable control arms and I delayed on raising the height and that's how i ended up getting wear.
For the amount done and the mileage on the car its worth the price compared to other car prices Ive seen around.
If your interested call me @ 770-five zero eight 5459 Ben
Interested in trading for only 2004 Audi a6 S-line or Audi S6 otherwise just want to sell
If some one is realy interested in the ride I could possibly fix the vibration and "Traction & ABS" Light
Or the way it is ill thrown in my 85mm MAF housing, MAF adapter to stock RS4 box (from 034 brand new) with the the stock RS4 box and 550cc injectors & 034 Silicone hose from the Y-Pipe to MAF Housing.
If anyone is interested I can also take it to the next Audi/VW meet in Savannah, Ga May 14-15
PLEASE do NOT call offering prices like 5k or 6k I will say No. I am in no rush selling.
