Results 1 to 3 of 3
    Established Member Two Rings CaliAllroad02's Avatar
    Aug 01 2014
    California
    Post Allroad Self Leveling Suspension.
    Hi Allroader, I have have an issued regarding front air suspension. I recently replace upper and lower control arm. In the process I removed the clip that hold the self leveler on the lower control arm, now my allroad sit really high in the front when park and engine off. I also did 402 mod awhile back if that make any different. What could be wrong with it. There is no error code. Any insight on this would be appreciated thanks.
    Aug 04 2009
    Glen Ellyn, IL
    Did you make sure to reinstall the sensor in the same way it was before?
    If it's in place where it's meant to be then you can should try 402 calibration.
    OEM+ work in progress allroad
    Unicorn Society member #8
    @fourings | Build
    Aug 01 2014
    California
    Thanks for the reply, I did put it back where it was. I will try to calibrate it again and see what happen. I'll do that after i fix this short to plus on my cam chain tensioner....
