Results 1 to 6 of 6
    Established Member Two Rings GerCarFan's Avatar
    Dec 25 2013
    B8 A4 2.0T and Camry SE 2015
    Cooper City, Florida
    Roof interior cleaning
    Hi guys. I have looked over google search, through audi and other car forums on how to remove stains, pen marks, etc from cloth material inside where the roof is, if that makes sense. Previous owner really did not take care of car at all and I am stuck here restoring the whole inside of a car.
    I have A4 2010 if that helps.
    The budget on the products is not a problem as long as it does its job. Thank you guys!
    Feb 17 2013
    Q7 . A3 3.2 Quattro and way too many cars in the garage.
    Burlingame
    What do you have to work with.
    Dec 25 2013
    Nothing :'(
    Veteran Member Three Rings DaveyDave424's Avatar
    Aug 02 2012
    LOS ANGELES
    Quote Originally Posted by GerCarFan View Post
    Nothing :'(
    I've been able to get some marks out from my interior using Mr. Clean magic eraser. I apply pressure as needed, start with light scrubs and wipe with damp cloth.
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    The fabric on the roof can be tricky.....I would assume that it would need to be steam cleaned. A good interior detailer may be able to do it for you.
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    Laquer thinner
