Originally Posted by
Gin+
I have a vibration that generally goes unnoticed unless I'm cruising past 80mph+, which is pretty rare. I don't recall feeling any vibration before having the transmission replaced. It's the same with my snow tires and brand new summer tires mounted on separate wheels so I don't believe it's tire/wheel related. The car was just aligned and drives like new and feels tight. I've inspected the center bearing and it appears all intact. No clunks or anything like that.
A friend of mine suggested that the factory balances the driveshaft to the transmission and that I should try clocking it until the vibration diminishes. Does that sound reasonable to any of you guys? Anything else I should be looking at? My fear is that somehow the driveshaft got knocked out of balance during the transmission replacement...
My B6 developed some vibes after my clutch install, I have tried re-clocking the driveshaft to xmssn output shaft 4 times by turning the driveshaft til the next set of bolt holes lined up but each try had no different or better result any of those attempts. My engine mounts were shot so I didn't really notice the drive train vibration until I put everything back together with fresh mounts all around and did some investigating.
The Bentley does have a procedure for clocking the final drive to the driveshaft but not the xmssn output to the driveshaft. Out of balance is not likely unless you changed some of the driveshaft components or took it apart and reassembled it differently, it could possibly be out of phase with the final drive, that is if you unbolted it from the final drive.
Did you allow the driveshaft to hang downward w/o support at any point during your trans install? That could possibly cause the U-joint to bind and cause your hi-way vibration.
