Results 1 to 16 of 16
    Registered User Four Rings UroTuning's Avatar
    Aug 23 2007
    Tampa Bay, FL
    B6 A4 1.8T Metal Coolant Flanges // UroTuning.com PRE-ORDER now LIVE
    After a few months of teasing we are moving forward with getting these flanges produced.!!
    Due to the extra machine work involved to make these the price will be $85.99.
    UPDATE: Parts are now IN STOCK and ready to ship out.
    Click here to order now - http://www.urotuning.com/Cooling-Fla...1132e-cast.htm
    Veteran Member Three Rings G.AUDI's Avatar
    Dec 07 2008
    MK6 GTI
    SGV, CA
    That is awesome!! I just replaced mine with the plastic one not too long ago but may look into upgrading to this. How much longer is this expected to last vs the plastic ones?
    Feb 12 2008
    Michigan
    same here, just replaced it for second time in 2 years.
    Veteran Member Four Rings ShogunR32's Avatar
    Aug 22 2004
    I'm wondering if the o-ring is more of a common failure point then the actual plastic. If that is the case, then these metal versions will leak as well regardless of their construction.
    USP CLUB MEMBER #7
    Previous Audis:Big Turbo 2005 Black Audi A4 USP 6-speed sedan/2008 Blue Audi A4 6 speed sedan/2004 OEM+ Arctic White Audi A4 Avant/2001 Red Audi TT 225Q.
    Current: 2004 BMP Vw R32
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by GTRchop88 View Post
    most of the failures I've seen have been when the o-ring lip fails (literally disintegrates) on the surface mating to the block; this will certainly resolve that type of failure
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Veteran Member Four Rings heywier427's Avatar
    Jan 08 2010
    - Dolphin '02 A4 1.8tQ, 91 Q45, 02 caddy ext, 85 datsun 720, 71 datsun 510, 08 Ducati 848, Mk1 TD
    CT Shoreline
    Purchased.
    Dec 05 2007
    Warping is also an issue. This is why OEM is always recommended for replacement. They warp less, but the o ring is most times the culprit. I ordered a bunch in different sizes from fcp before, and they have saved me money more than once. Reason being, most times it is just an o ring issue (more than this app).
    Dec 19 2011
    Colorado Springs
    Common issue I've come across is a leaky Cam chain tensioner gasket gets oil onto the o-ring and boss for it and causes it to degrade causing the coolant leak..
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Veteran Member Four Rings AvantNoir's Avatar
    May 22 2007
    Santa Monica CA
    Gonna be ordering one of these in the next 2-3 months. Mines going bad. Thanks for stepping up and manufacturing this!
    2005 USP A4 Avant 1.8T Follow me on instagram @m27autowerks
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    I broke this thing fighting to get the heater core hose off.
    Aug 14 2010
    Hattiesburg, MS
    Will this work on a 2003 with the AMB engine?
    If not, will one be available for the AMB?
    Mine is leaking and I'd rather do the job once and be done with it.
    Thanks...
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    Costco 92 Octane Gas - MANN Air Filter - 235/35/19 Tires w/ 36 PSI (cold) Tire Pressure - Grey Plastic Valve Stem Caps - 0° Front Toe - Rotella T6 5W-40 - 2 OEM B6 Keys - 18x8" Spare - Coin & Pen Filled Center Console - Rain-X on all 8 windows & Napa Cold Temp Washer Fluid - Bosch Wiper Blades (Valeo wipers suck big time!) - S4 Trunk Latch - Craftsman Tire Pump w/ Automatic PSI Shutoff - Belly Pan Delete (Weight Savings) - 3D Printed Rear Warning Triangle latch - 174,000 Miles & Counting
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Yes. Finally.
    Senior Member Two Rings shoemaker617's Avatar
    Nov 15 2011
    east coast
    Finally! Take my money! My order is in
    Sent from my SAMSUNG-SM-G900AZ using Tapatalk
    Aug 23 2007
    Tampa Bay, FL
    Quote Originally Posted by DPRider2 View Post
    Thanks...
    Sorry had a typo on the page. This is the part for the AMB 2002-2005 Audi A4 1.8T - expecting to start shipping these Late May
    Aug 23 2007
    Tampa Bay, FL
    bump up. will have these very soon !
