Results 1 to 3 of 3
    Veteran Member Three Rings frmomiller's Avatar
    Apr 22 2011
    BMW335i 07, Yamaha FJR1300 08
    Sheffield, IL
    Carbotech XP10 Audi A4, S4, RS4 B7; A5, S5, RS5, A6, S6, RS6, Q5, rear brake pads used - No Longer Available
    CT1018, XP10: Used 6 track events, thicknesses range 14-15 mm with back plates. New I believe pad material was 12mm, back plate is 5mm, so total 17mm. 10mm is minimum, so just over 50% material remains. Bought new and started using early 2014, rear pads were around $250 new.
    Fitment:
    A4, S4, RS4 B7; A5, S5, RS5, A6, S6, RS6, Q5, but check the years. Mainly mid to late 2000s to early 2010s.
    List Date: 4/19/2016
    For more info, click here to view the original listing: Carbotech XP10 Audi A4, S4, RS4 B7; A5, S5, RS5, A6, S6, RS6, Q5, rear brake pads used
    This item is no longer available.
    Senior Member Three Rings guglielmo's Avatar
    Feb 02 2008
    Westchester, NY
    Just a heads up that size fits B8 A4,S4,S5 Q5s and others.
    http://www.ctbrakes.com/pads.asp?Make=Audi
    B7 RS4 mugello
    B7 S4 moro
    Q5 meteor
    Apr 22 2011
    Sheffield, IL
    Dito what he said
    I knew the rears fit more models. Thank you
    Quote Originally Posted by guglielmo View Post
