Results 1 to 7 of 7
    Established Member Two Rings ironman9's Avatar
    Jan 25 2016
    Brunei
    Cool time to go fast!
    Hi guys. I have a 2013 Audi A5 2.0t coupe tiptronic. My car is also not quattro (lame :( )My friends are asking me to do ECU flash. what do you guys recommend? APR ECU flash?
    Another thing is, is it safe to do that?
    In terms of long-term on the engine and gearbox. Will it be safe? If i were to do this, is there any parts that I need to change? for example the air intake things and etc. I am completely new to all these and have no knowledge about it. Really appreciate it if you guys could explain to me.
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    Stage 1 Apr intake is optional, stage 2 I believe they say you should do intake and exhaust. Otherwise it should be safe. I haven't heard any stories of issues specifically because of APR, but if you have other engine related issues Audi may deny warranty claims.
    My local shop has offered to flash back to stock if anything comes up before i take it in for service.
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Veteran Member Four Rings essfour's Avatar
    Dec 03 2010
    Boston
    Yes, totally safe. A stage 1 tune from APR or GIAC will make a big difference, and no parts will need to be changed out - just a quick software flash. Although I'd recommend committing to changing your oil every 5k and possibly running higher quality stuff than what your dealer may offer - Mobil 1 Euro 0-40 will do the trick - and it's pretty cheap.
    If you want more power you can always do a high preasure fuel pump and high flow catalytic converter and go for a stage 2 tune from someone like APR. If you want more power than either of those options then you'd be talking about having to go for a larger turbo/fuel injectors/intercooler. Still safe for the transmission considering you have the 8 speed gear box which is very strong and the engine can more than cope with the stress - the 2.0t is pretty tried and true with a lot of people tuning them with little issue if done right and with quality software and supporting hardware.
    good luck
    2022 Daytona RS6
    2020 Alpine White X7 50i
    1987 E30 325ic 5spd
    2018 Tanzanite M3 ZCP - sold
    2013 Phantom Black RS5 w/ Alu Optic package - sold
    2011 S4 6MT Meteor Grey w/ Ti package - sold
    2008 A4 S_Line Avant 2.0T 6-speed - sold
    2006 A4 Sedan 6-speed - sold
    2001 A4 Sedan 5-speed - sold
    Jan 25 2016
    Brunei
    ah ok. thank you! in my country, alot of people are using this thing called Racechip. it is cheaper than doing an ECU flash. you guys heard of that before?
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    Quote Originally Posted by ironman9 View Post
    Piggyback systems like RaceChip are a pretty common alternative to ECU flashes, at least on the 3.0T motor. Although the piggyback unit of choice on these forums (this/S4) seems to be ChipWerke. I found a few threads on RaceChip by using the search, might be faster than waiting for someone to respond.
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Sep 27 2015
    OH
    I have a 13 a5 quattro and have been looking into APR stage 1 & 2. I have a k&n air intake filter just a drop in one and also plan on installing a gfb DV+ which I picked up off ebay.
    As for the APR ecu flash I'm not sure which one I'll go with, pending cost I may just jump to stage 2. I have a few months left on my warranty before I do anything although I may not wait
    stage 1: no parts required
    stage 2 : down pipe
    numbers for stage 1 & 2
    http://www.goapr.com/products/ecu_up..._long_b85.html
    Jan 25 2016
    Brunei
    Ah okay. Thanks so much for the info guys!
