Results 1 to 11 of 11
    Jun 07 2014
    phila pa
    headliner material
    my avant has a case of the sags. i am thinking about using black faux suede or alcantara. not really sure what to do as the rest of the interior is "like new". anyone know where i can get factory material or have pics of what other material looks like when installed?
    Nov 15 2011
    Montreal | I sell in USD
    Quote Originally Posted by rgtorque View Post
    Find an platinium silver headliner from an avant an spray it with Dupli Color HVP106 (Flat black fabric dye). You'll need 4-5 cans and the color comes out the same as the oem anthracite.
    *****I sell in USD*****
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    This is what I should of done, but instead I bought suede and rewrapped the headliner and all the pieces. the suede is a little thicker than the factory stuff so a couple spots I had to really force the pieces in.
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    I do headliners a lot for friends and myself, i had to redo mine, I got a semi stretch material and used a heavy duty headliner spray, I had to remove the old material and scrape all of the old padding before I went to work on it.
    small part i miss-cut and shrank. not noticeable in car though
    if it starts to do the same again, there are a bunch of videos on youtube on redoing the whole thing. Good luck and hope it stays up for you, post pics if you can. love to see other peoples work.
    Veteran Member Three Rings Kevinskir's Avatar
    Feb 03 2010
    Portland Oregon USA
    Quote Originally Posted by Axis View Post
    Find an platinum silver headliner from an avant an spray it with Dupli Color HVP106 (Flat black fabric dye). You'll need 4-5 cans and the color comes out the same as the oem anthracite.
    Hmmm If I keep striking out on finding a black headliner I might do this.... Local upholstery shop quoted me ~200 to redo to the material professionally, but thanks for the info :)
    2008 Ibis S4 Avant- Driving in a Unicorn, moving by Llamathrust
    Stasis Exhaust with Piggies| JHM 91 Tune | JHM Short Shifter| PSS9 Coilovers|
    2007 Sprint Blue RS4- Sold and off to a new stable
    2007 Volcano Red Plasti-dipped A4 2.0T Quattro - Sold
    Jan 29 2010
    north ga
    that sounds like a great price. My avant also decided to get a saggy but this past year. I was thinking of going the route of pulling the rear dome light and spraying some adhesive to fix it. I really didn't want to have to go to the trouble of pulling the whole avant headliner. I haven't looked up the process, but I'm sure it is a bit of a pain with about 100 little clips involved that I would likely break
    Jun 07 2013
    West
    Isn't the main portion supposed to match the perimeter pieces?
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Im about to do full suede interior. Dashboard center console pillars and headliner.. I will report back in few months when i finish it lmao
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Oct 05 2015
    Billings, MT
    Quote Originally Posted by Lucca M View Post
    Please do!
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    I did this on my old car, just be away that the fabric will no longer be as soft as it used to be.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Nov 15 2011
    Quote Originally Posted by melomandn View Post
    Agreed
