Results 1 to 7 of 7
    Feb 17 2015
    Ontario
    KW HAS Clicking Noise
    Hi guys,
    I have KW HAS system installed on my S5 and I am getting very annoying clicking noise when turning the steering wheel left or right... even slight movement in the steering wheel creates the noise. What thing I should be looking to check where the noise is coming from? When the car is on jack, the noise disappear...
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    How long ago was the kit installed? Mine used to creak and make noise when new. It took over 1k miles to settle - no problems since.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Feb 17 2015
    Ontario
    Quote Originally Posted by SLU_S5 View Post
    The kit was installed last summer, but I raised the car in winter and the noise started but I lowered the car over the weekend and now the noise is so much more with little movement of the steering wheel...
    Established Member Two Rings Zonsolo's Avatar
    Sep 14 2015
    OH
    Anyone else experiencing this? I have a set of HAS sitting in the garage and don't want to put them on if it's going to sound like that.
    ►Zonsolo◄
    2011 S5 6MT AWE Touring KW HAS Custom Hypersilver Niche Targas 20x10.5 Hankook 285s
    Sep 06 2014
    Rochester, NY
    My guess is that something is off in the way that the spring is seated. Mines been installed for over a year with no problems to date.
    IG: @SLU_S5
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Check the top mount is free to rotate, if it isn't turning then the spring will be moving on the lower spring seat which could make that noise.
    Did they reinstall the washer at the top of the front struts?
    Active Member Two Rings jaygemson's Avatar
    Feb 05 2014
    United Kingdom
    My KW HAS kit has just started making this noise after a year of silent operation, and no changes at all to the suspension setup.
    Be interested to know what the cause was in your case. I suspect top mounts too.
    Audi S4 3.0V6T Deep Sea Blue Pearl [2010]
    MRC tuned, Ohlins coilovers, Team Dynamics Pro Race 1.3s, Milltek non-res, RS5 Brembo 8-pots, RS4-style front, RS5 rear
