Results 1 to 40 of 53
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    Help Me Align My AWE Exhaust...Again...
    I've had my AWE exhaust for about 2 yrs now and I absolutely LOVE the sound.....the part I can't stand is it's tendency to move around over time. Has anyone found a way to keep this thing aligned properly? I'm going to get my indy shop to mess with it soon but thought I'd ask here first to see if anyone has any tips on how to get it aligned properly. Here are some pics (Yes...I know the tips are dirty ;)). The left side is actually pretty perfect but the right side is at a slight angle and almost touching the stock diffuser.
    Left Side
    Problem Side - Right Side (see how it's almost touching the diffuser...
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Senior Member Three Rings AudiS4TW's Avatar
    Sep 16 2013
    San Diego, CA
    Photos are missing.
    Sent from my iPhone
    2014 Audi S4 Premium Plus- Blessed with a manual transmission
    AWE S-Flo/Touring Exhaust/Non-res DP, Magnuson Stg 3 SC, AMS Alpha System, Eurocode AK/Meisterwerk STS/USS Sways/End Links, KW V3, SPC Control Arms, HRE FF01, PSS, Deval CF Rear Valence, RS-style grille, Ecode Headlights, CQuartz Finest, 3M Crystalline 60% Tint
    Sexy, Sleek, Stylish, Sporty
    Veteran Member Three Rings Krusty's Avatar
    Sep 19 2012
    long beach
    Your pics are broken.
    2011 sprint blue s4, EC subframe stabilizer, ECS short shifter, Euro Impulse weighted shift knob, custom air intake, RS grille, CR-15, 034 rear diff mounts/rear diff carrier mount inserts, Apikol rear diff mount insert, 10mm(f)/12mm(r), ECS strut tower brace, ECS front adjustable end links.
    Jul 20 2012
    Just fixed the pics.....see above.
    2013 S4
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    I have given up on mine, no one else will notice it but you.
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Mar 21 2015
    Mines off a hair on that side too but not that close. It's been about 8 months for me and thought about effin with it again.
    Jul 20 2012
    Quote Originally Posted by B8 S4 View Post
    I'm gonna get it right then weld that M'Fer in place!
    2013 S4
    Oct 06 2013
    United States
    I had that issue as well...the shop that installed it (props to KMD Tuning) had adjusted it twice for me to get it right. What they ended up doing was putting a clamp on the muffler hanger to prevent it from sliding over any further than it should be (the clamp keeps it centered on the rear valence cutouts). They recommended welding it in place but I wasn't too keen on doing that in case the exhaust ever needed to be removed. However, so far the clamp has held up perfectly over the past 18 months.
    Jul 20 2012
    Quote Originally Posted by Meteor View Post
    Any chance you can share a pic of what you're talking about. I have an idea but a pic would help. I'm not opposed to welding a little bit just to get this thing to stay put. Can always break the weld later if you really need to.
    2013 S4
    Oct 06 2013
    United States
    Yea no problem. ill post a picture tomorrow
    Jul 20 2012
    Thank you sir!
    2013 S4
    Veteran Member Three Rings KRS Aaron's Avatar
    Jan 25 2011
    Evanston, IL
    I have the same issue and I'm about to go at it another try. I'm thinking about taking it apart and putting it back together again since it all keeps moving on me and I suspect that some area may be under some tension. I may also try to upgrade to the bigger tips before I do so since I have the Deval diffuser.
    2024 RS6 Performance - Nogaro Blue
    2012 S4 - Nogaro Blue
    2017 Aston Martin V12 Vantage S - Onyx Black
    1994 BMW 850 CSi - Mauritius Blue
    M2 CS Racing
    Oct 31 2013
    Morris County, NJ
    Mine look exactly the same. I just learned to live with it.
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige (SOLD), 2016 Audi C7.5 A6 Prestige (SOLD), 2004 Audi C5 A6 4.2 - 6spd
    Charlotte, NC
    Use HD zip ties till you get the adjustments right.
    APR Stage II+ | APR TCU | APR Ultracharger | APR Dual Pulley | APR CPS | APR Open Intake | AWE Non-Res DP & Touring | H&R Coilovers | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Adj Arms | 034 Arms Kit | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals Shifter | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
    Nov 12 2015
    Here
    Had the same exact fitment issue on mine - left side centered, right side... not. My exhaust shop was able to get it straightened out, but took some work including heating and bending one of the pipes slightly. Once they nailed it they tack welded the joints. Has been perfect for 3k miles now.
    Mein ist grau
    Jul 20 2012
    Quote Originally Posted by SportVier View Post
    I was thinking that heating and bending may be the call here as well.
    2013 S4
    Oct 06 2013
    United States
    Quote Originally Posted by creativecody View Post
    Thank you sir!
    As promised.
    Here is the clamp to keep the exhaust lined up:
    Where the clamp is attached (circled in orange):
    Jul 20 2012
    As promised.
    Thanks man!
    2013 S4
    Stage 2 Banner Advertiser Four Rings Josh/AWE's Avatar
    Feb 08 2012
    Horsham, PA
    Hi, guys!
    We supply hanger clamps for this reason, and it's called out in the install instructions as well.
    Full guide (click me)
    Performance Specialist
    AWE-Tuning.com > 1.888.565.2257
    my email > facebook > twitter > instagram > youtube
    Sep 13 2010
    Charlotte, NC
    Quote Originally Posted by Josh/AWE View Post
    Hi, guys!
    I cosign this post.
    I personally used zipties on the rubber hanger part if it hung too low on one side versus the other, but yes these clamps work well for horizontal alignment.
    Jul 20 2012
    Hi, guys!
    Thanks Josh! Looks like I'll be climbing under my car tonight to see if those are even there. Maybe they were never installed or came off.
    2013 S4
    Feb 08 2012
    Horsham, PA
    You're welcome :)
    Mar 21 2015
    Even with those on you will still have to loosen the center section to get it over to the right. I have those clamps and they don't help in that direction on the passenger side.
    Jul 20 2012
    Interesting. I think what Meteor did in his post further up this thread may actually be a better call to combat this issue. He put clamps on the other side of the rubber element to prevent the tips/muffler from moving towards the center of the car.
    2013 S4
    Mar 21 2015
    I agree but you will still need to loosen the center section I believe. Mine stays in one spot and doesn't move now, I just need to get it to the right.
    Feb 08 2012
    Horsham, PA
    There is opportunity for adjustment in the brackets holding the hangers, gentleman.
    Jun 29 2015
    I found the exhaust a PITA to get lined up properly. Don't bother putting the dope in on first install because you are guaranteed to do it more then once to get it right.
    Then when you go back you can add the sealer to the joints but even with plenty applied I still hear leaks, especially when exhaust is cold.
    For the money I could have had a custom exhaust fabricated locally which in hindsight I should have after seeing the guys work.
    Senior Member Two Rings grrrrrrr's Avatar
    Mar 27 2008
    valencia, california
    i too have issues with the right side as it is angled towards center of car and pointing downwards. both sides of the exhaust are pointing towards the center of car. Any advice what to tell the guys at the shop to fix alignment.
    Sent from my SM-N920I using Tapatalk
    Jul 20 2012
    After crawling under my car I think the issue is that the cross bracket, which connects the two mid section outlet pipes loosens over time causing the right side to push inward, towards the center of the car. Do you think this cross bracket could just be welded to keep it from moving? I'm also considering putting a clamp like Meteor did on one side of the rubber element to keep the tips from sliding further over.
    2013 S4
    Mar 27 2008
    right side is off pointing downward.
    Mar 27 2008
    could you show in the photo where the cross bracket is. thanks.
    Mar 21 2015
    Quote Originally Posted by grrrrrrr View Post
    At the V at the top of the pic
    Nov 29 2013
    Silver Spring, MD
    Just looked closer at my right side...sigh, i have it too. wtf!
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Senior Member Three Rings noyzcij3's Avatar
    Sep 06 2012
    Philadelphia
    I've been trying to fix mine for a while too, but my problem is quite the opposite. Both outer sides are slanted downwards. But at least they're just about evenly slanted.
    2016 Sepang S4 P+
    6MT | Black Nappa Leather | Tech Package | Carbon Inlays | Sport Diff | Vag Com Mods | Xpel Ultimate | Ecodes | BFI GS2 | Carbon Mirrors | Alu Kreuz | 034 Drivetrain Mount Inserts | Bilstein B16 RideControl | Eurocode Sway Bars and End Links | AWE Resonated Touring Exhaust 90mm | BBS CH-R | Deval Diffuser | Ecode Taillights | ECS Street Shield | 034 Subframe Mount Inserts | Carbon Imports Low Kick Spoiler | Porsche 19Z BBK
    Mar 21 2015
    ^ That should be easy with adjusting middle bracket.
    Nov 29 2013
    Silver Spring, MD
    Quote Originally Posted by noyzcij3 View Post
    Correction...^This is what I have. (Dat diffuser doe , lol)
    So this is what I need to target?
    Mar 21 2015
    ^ Yes but you might need to loosen the two rear clamps to get the rotation of the pipes.
    Sep 06 2012
    Philadelphia
    I tried adjusting at the V, while it did align the two left tips a bit better, but it angled the whole muffler downwards at the back compared to the right. And if I angle the right muffler the same way, the two tips get misaligned on that side.
    2016 Sepang S4 P+
    Mar 21 2015
    I had the worst time doing mine on a lift. I got it close and left it that way and haven't touched it since. I might not touch it cause it is a pain. It takes some patience.
    Mar 27 2008
    Can AWE rep point where to adjust specifically to fix alignment. tnx in advance. My OCDness is killing me
