Results 1 to 40 of 75
    Veteran Member Three Rings vwnobby's Avatar
    Mar 30 2009
    '07 A4 S Line / '97 Jetta GLX (sold) / '96 FZR600
    B7 S4 rear brakes, anyone do the upgrade?
    Looking to get something better for rear brakes, so considering the S4 rears. I noticed that the part numbers are the same for the A4 and S4, with the exception of the last letter. 8E0615423H for A4 left and 8E0615423J for S4 left. Are the calipers really different? Or is itmlike the fronts where you just need different carriers?
    Nov 15 2011
    Montreal | I sell in USD
    Different
    *****I sell in USD*****
    Account Terminated Four Rings
    Jan 15 2016
    '08 A4 2.0 Avant 6MT S-Line Ti
    SoCal 626
    I thought only the carriers were different(allowing for a larger rotor) but the calipers were the same ?
    May 20 2010
    No, they're physically larger, IIRC. I've done the upgrade a few years ago, and that's what my recollection is. Either way, they're an easy and cost-effective upgrade. The parking brake cable slots right in, but because of the slightly different/farther attachment point, you may want to loosen and re-tighten the brake afterwards.
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Search
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Veteran Member Three Rings RickB_7's Avatar
    Feb 26 2015
    Tacoma, WA
    Just did this a few weeks ago. I found a set in a junkyard off a B6 S4 and told the person at the front desk they were off a mk4 jetta and got them for $35 then bought ECS slotted rotors and painted the calipers. You won't need the dust shields, everything else goes back together very easily and you'll just need to loosen the e-brake cable to get it on. It's really funny ECS sells the whole "stage 2" kit for $1,300 when I pieced together the same thing for a little over $250. Also, in my experience the Akebono brake pads are really good I really can't believe how there is virtually no dust from my rear brakes.
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    I'm also in the middle of doing the conversion. I didn't really compare the A4 and S4 calipers side by side. I'll check it out tomorrow if I have time
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Mar 30 2009
    Quote Originally Posted by jerseybrian View Post
    Thanks, I'd be interested to see the difference side by side.
    Quote Originally Posted by RickB_7 View Post
    That's exactly what I was looking to do. I found a set for relatively cheap a short while back, but missed out on the sale. Looking to see if I can sorce them soon.
    2.0T MTQ | Revo Stage II+ | APR HPFP | 034 Engine Mounts | 034 HFC | 034 Turbo Inlet | ER SMICs | TT 2.5" DP | Magnaflow 16601 DP back | K&N Drop in filter | ECS Snub mount | RS4 Rear Sway bar kit | B5 lowering caps | "D" piston DV | TyrolSport Caliper Bushings | S4 Front Calipers/Carriers/Rotors | Goodrich SS lines | StopTech Street Performance Pads (Porterfield R4 for track) | AWE Vent Boost Gauge | NGK (4644) BKR7E (replaced NGK Iridium BKR7EIX-11)
    Jan 15 2016
    SoCal 626
    Well I know that the B7 S4 and A4 share the same front calipers, the only difference is the carrier is larger on the S4 allowing for a larger rotor.
    So I am surprised to hear that the rear caliper is actually bigger, rather than having just a larger carrier.
    @jerseybrian if you could get some side by side pics that would be awesome so we can actually compare the two
    Jul 15 2011
    Boynton Beach, FL
    Quote Originally Posted by malathion View Post
    Yea, I haven't been on AZ in like 4 years consistently and from what I remember, I thought you just needed the rear carriers for the rear conversion as well, but then I was corrected recently so I went ahead and bought rear S4 calipers off a part out. I'm currently dealing with some fitment issues with my wheel setup and the calipers (I have a 3" lip) so I will try and get a photo up for you soon.
    Jan 15 2016
    SoCal 626
    Hahaha I'm also dealing with some wheel fitment/caliper issues, my lips are only 2.5 inches but my wheels are 19x9.5 +36 square
    Running the Porsche Cayenne 18z up front and the wheels are hitting the calipers so I gotta do some "massaging" to the calipers
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    Also in the process of doing this conversion. From what I have been told, the piston on the S4 caliper is definitely bigger which would make me think that the entire caliper is bigger.
    I do remember reading somewhere that A4 calipers would fit in S4 carriers but that may have been mis-information. Side by side photos would be great for curiosity sake.
    @Axis has done this conversion so I'd take his work for it!
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Mounts - APR Snub - S4 RSB - 034 Turbo Inlet - JHM Short Shifter - Porsche 345mm Brembo Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension/B5 front cups - Black Alcantara Recaro Interior - RoadNav/S100 Headunit - Summer: 19" OEM S5 wheels, 19x8.5 ET32 - Winter: OEM 18" RS4 stye wheels, 18x8 ET43 w/ Nokian studded tires - Dolphin Grey FTW!
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by drewgold View Post
    The piston is only 1mm bigger
    Jul 15 2011
    Boynton Beach, FL
    I hear ya. My fronts have already been modified lol aaaaaaand the rears are being modified everyday at work lol. I have 9.5s in the rear with a +30 offset lol
    Nov 15 2011
    I had the pistons out of the S4 calipers for powder coating purposes, I should of measured width and lenght to compare with the A4's.
    drewgold, I didnt install them yet, I'm actually finishing rebuilding the front Brembos and then installation time.
    Sep 21 2004
    Quote Originally Posted by Axis View Post
    Gotcha, thought you already had them on. I'm pretty much at the same point, working on painting the fronts and media blasting the rears. I know the part numbers are different for the seal kits so there must be some difference in size, even if it is only 1mm.
    Did you take the parking brake mechanism apart or just the pistons? I'm debating whether I should disassemble the whole thing or just leave it as the parking brake seems to be working fine.
    Nov 15 2011
    I took the whole thing apart and had everything powder coated, I was actually about to post a question here which you might be able to answer :
    Two different part number for the ebrake mecanism springs 8E0615295D -left & 8E0615296D -right. Which one is bigger? I have them both springs in my hands but dont know which is which since obviously no part number stamped on a spring.
    From ecs images, the small one seems to be left.
    Sep 21 2004
    Two different part number for the ebrake mechanism springs 8E0615295D -left & 8E0615296D -right. Which one is bigger? I have them both springs in my hands but dont know which is which since obviously no part number stamped on a spring.
    Both of the springs on my calipers are the same size. (Left caliper on left and right on right in pic) The calipers are from a 2005 S4 in case that makes any difference. Let me know if you need other pics. I suppose orientation of the spring is what's important and different from left to right.
    Did you have any trouble getting the parking brake mechanism apart? Is there an internal spring that needs to be compressed?
    Mar 30 2009
    RickB_7 did you keep the A4 dust shields and adjusted them or just no dust shield at all?
    Nov 15 2011
    Meh @10$ each I'll order two new springs since I obviously have one that does'nt belong there. Thank you!
    I had a local shop take the ebrake mecanism apart since it's a pita. They charged 40$ to take the pair apart and bead blast them and another 40$ to re-assemble.
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    -Alex-
    07 A4 2.0 TFSI Quattro,Rebuilt engine, BPG pistons, S-Line interior, S-Line suspension, S4 brakes, RNS-E & Bose
    Mar 30 2009
    Just sourced a set of 07 S4 rear calipers and carriers. They wouldn't sell me the dust shields because they keep those with the spindles (parts place).
    Now need to find the dust shields, rotors and pads and should be good to go. Hopefully calipers are in good shape.
    Veteran Member Four Rings thenofjboy's Avatar
    Oct 08 2007
    08 S-line QMT6 , B5 KO4 & my german sheppard
    Jersey City
    I'll be installing my B7 S4 full brake setup soon, hopefully this weekend. One of the dust boots on a rear caliper was ripped, so I rebuilt all 4 calipers before I painted them. Super easy DIY.
    For those that are doing this swap, I'd seriously considering rebuilding the calipers bc they are off the car and getting SS brake lines. I got the rebuilt kits from RockAuto and the rotors from AutoAnything and I can post the receipts w/part numbers if that helps anyone.
    Sean
    The New
    B7---GIAC--BBS--DDM--JHM+S4Exhaust--StaSIS SS--034--AudiUP--USP--RedEBC--IE--DrakesVC#12--B7S4 Brakes--StopTech--GFB DV+--
    The Old
    B5---GIAC-K04--RACETEC--APR--DEPO--AUTOTECH--VMR--FORGE--034--H&R--BILSTEIN--FUJITA
    Jan 06 2012
    Chicagoland
    Getting ready to do this as well. Started breaking down the calipers last weekend. Any part nos. appreciated.
    Oct 24 2015
    Perth, WA
    Since rear braking is less important than front, what benefit do you guys anticipate? Is it primarily the 'look', or is it for track work, or simply im wrong and the difference is night and day. Cheers ;)
    My respray thread
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    Anyone know if the rear caliper spring mechanism from a b6 fit the b7 s4's? I'm going to throw them on this weekend, hoping they do swap over.
    Dec 04 2011
    Kansas City, KS
    Larger caliper piston increases brake pressure on rotor. Larger rotor that is vented increases cooling and move lever arm of brake pad, thus increasing mechanical torque.
    And it looks better with a bigger rotor back there
    Mar 30 2009
    Quote Originally Posted by Okedokey View Post
    I did the S4 front setup a while ago and I track my car once or twice a year. With the S4 fronts, running track pads, during heavy high speed braking I've noticed the back end of the car get a little loose. I'm hoping that this will help even it out a bit. Plus, going from a solid rotor to a vented rotor will help, I'm sure.
    Nov 15 2011
    Quote Originally Posted by gmudan View Post
    From what I saw on ecs they share the same part number so yes, same springs.
    @Okedokey: I will run Q5 fronts so they will even out the braking balance.
    Sep 21 2004
    Quote Originally Posted by vwnobby View Post
    From what I can tell (and measure) you shouldn't need new shields. There is plenty of space on the shield to accommodate the larger diameter rotor, you may need to trim the shield a bit though to fit around the S4 Caliper.
    Feb 26 2015
    Tacoma, WA
    I did not have to use the S4 dust shields though I do have them. The S4 rotors are only slightly larger in diameter than the A4 rotors and they fit no problem in the A4 dust shields.
    I have some Brembo 18z up front and I could definitely feel that the front over powered the rear brakes. With the S4 rear brakes I would say it feels more balanced and there is less drama under very hard braking.
    Oct 16 2008
    South Florida - Ft Lauderdale
    And just in case you are looking for 300x22mm slotted rotors:
    $7.63 a piece
    https://www.rockauto.com/en/partsearch/?partnum=980516
    These are coming form an old NAPA store closeout
    Phil
    Nov 15 2011
    $7.63 a piece
    Phil
    Wow!
    Oct 16 2008
    Wow!
    LOL, yes
    Phil
    Veteran Member Four Rings Quattro 4 Life's Avatar
    Feb 05 2008
    '64 Pontiac Catalina
    Kenmore
    $7.63 a piece
    Phil
    These gone already? Can't find em...
    Edit: original link wasn't working, found em.
    2007 Ibis White B7 A4 Avant 3.2QM Titanium - 1 of 2 | 2013 Glacier White Metallic 4L Q7 3.0 TDI
    Past: 2013 Phantom Black C7 S6 Stage 3 | 2003 Brilliant Black C5 S6 Avant | 2011 Quartz Grey C6.5 A6 3.0T Prestige | 2000 Silver C5 A6 2.7TQM | 1999 Laser Red B5 A4 1.8TQM PC-16
    Nov 15 2011
    Quote Originally Posted by Quattro 4 Life View Post
    Shows 16 left for me
    Feb 05 2008
    Kenmore
    Found them. Never seen a slot pattern like that.
    Oct 16 2008
    Still, for that price
    Phil
    May 20 2010
    Why does it say 2009 for the year when I click on it?
    Feb 05 2008
    Kenmore
    Phil
    Oh it's an absolute steal! I'm tempted despite having zero need for these. Ya know, for that future rear brake upgrade.
