I have read several threads regarding this topic but have found little information to help secure my decision as to which route I want to go.
I have sourced information from the following sources and thread
http://www.audizine.com/forum/showth...rmation-thread
http://www.audizine.com/forum/showth...-B6-compatible
http://www.audizine.com/forum/showth...t-3076-haltech
http://forums.vwvortex.com/showthrea...knowledge-dump
http://www.vi-pec.com/techdata/ecu-m...-plugin-manual
Before people start flaming and making the " Why do you need all that posts" I'm going to start with the limitations I have ran into utilizing stock-like management systems including Eurodyne, but first the contenders.
Option 1) LinkEcu TTLink (G4+)
http://www.linkecu.com/iPA1_2
Option 2) Vi-Pec i88 i-Series Plugin
http://www.vi-pec.com/ecus/iseries__pluginecu
Option 3) 034 Motorsports IIC Standalone + Tach adapter add on
Product has been removed from 034's website but is still available via Jeremy @ 034.
https://store.034motorsport.com/tach...tage-tach.html
Option 4) Eurodyne Maestro7
Not something I want to do due to limitations to be listed below.
Option 5) AEM EMS
http://www.aemelectronics.com/produc...iv-18t-engines
The issue I have found with Eurodyne through experience tuning a friend's car with a similar set-up to mine is the Limitations of the ME7 ECU to support additional inputs and/or change the OE sensors to aftermarket units. Eurodyne only really has support for larger diameter MAF housings and sensors, however no support for a higher psi MAP sensor or additional Oxygen sensor inputs.
0v on the OE WBO2 is roughly 10.9:1 AFR (0.75lambda) and a 5v of 58:1 AFR (4.* Lambda) this means that the useable range of the sensor is roughly 1.25v.
figuring that O2 data is linear, so 5v = 58, 2.5v = 29:1, 1.25v = 14.5:1 AFR so thus 0v to 1.25v is the only useful data for tuning, being 10.9AFR to 14.5AFR.
While most aftermarket O2 sensors and WBO2 integrated ECU's run 5v = 22.**:1 AFR, and 0v = 6:1 give or take..thus making much better use of the 5v reference and providing superior resolution and accuracy for air fuel ratio.
next, the OE Map Sensor seems to have a maximum psi limit of roughly 22-23PsiG, and you are unable to simply plug in a larger resolution MAP sensor (3bar, 3.5, 4) and change the Voltage table and offset to allow for more boost.
These are the major limitations of using Eurodyne which essentially gives you Partial but not full control of the OE ECU. While it works, it's not ideal for larger set-ups or those who want to run more boost.
Next, I have seen a few people on the 'zine and Vortex successfully integrate a Vi-Pec i88 / v88. However those who have done it successfully are scarce to share information as to how they made it work.
LinkECU, the sister company to the New Zealand based Vi-Pec sell the TTLink+/G4+ which appears to be the same as the Vi-Pec IPA-1 for a slightly reduced cost, I found the TT+ for about $1600-1700. Which is the same or similar cost to the 034 IIC that Hood is using. However, similar integration issue may occur and I'm not sure if the DBW is going to function correctly, might require a DBC conversion, as well as the issue with the tach signal which I discussed with Jeremy @034 earlier today.
034 Standalone, IIC (2C) is the only viable option as it allows full fuel/ignition/boost control, yet will require a DBC conversion and an additional module to keep the OE Tach signal working on the gauge cluster. However, the 034 system has not had any additional support since 2010 and thus appears to be a dying platform with little to no support.
Essentially what I'm looking for now is, what system should I use if cost were not an issue for the best integration utilizing some factory features (ESP) while maintaining optimal engine control.
I need something that will allow additional inputs and outputs, ie. MAP Sensors, Electronic Boost Control Solenoids, Air Intake Temp Sensors, Flex Fuel Sensors.
As for the issue of VVT being unsupported on the Vi-Pec/LinkECU, that can easily be overcome by running a trigger to the Cam chain tensioner to activate the "VVT" with a set of conditions such as an RPM >= and <= parameter.
Hoping to get some answers and support from those of you on here who have used systems outside of the OE ECU and how you integrated them into the car.
- Dave.
