Results 1 to 22 of 22
    Veteran Member Three Rings BlueSVT's Avatar
    Oct 06 2013
    Engine cover warranty claim
    I was showing the engine of my S6 to a guy at work last week, and the insulation layer underneath the cover just straight up fell off... the 8 or so points where it's adhered to the plastic cover just separated. Obviously this area experiences high heat, and it looks like the adhesive just broke down over time.
    Getting my car serviced as we speak, and they're replacing the cover under warranty. What was interesting, is that they said they had to order the "3rd revision" of this cover! That means there's clearly been issues with this over the model release, and hopefully this will fix it.
    Just a heads up for those of you with a 13-14 model and still in warranty... I'd pry that sucker off myself, to get the new updated cover that will hopefully last longer! Haha. I'll see if I can spot the difference when I get the new one.
    Arguing with an engineer is a lot like wrestling with a pig... After a couple hours you realize the pig likes it.
    Feb 11 2016
    earth
    Thanks for the heads up and please share the difference if you can
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by fatboydelights View Post
    Yes, and the part number too. Thank you.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    This is funny, I forgot to post a similar story here - same thing happened to me! The new cover took 3-4 weeks to come in (presumably from Germany?). It just arrived at my dealer recently, I need to swing by and grab it.
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    Yeah. My insulation section has separated from the top cover. I guess it's okay if it just lays on top of the turbos? I'll need to stop by dealer and see if I can get a new one ordered as well.
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Aug 29 2011
    Cape Town South Africa
    Thanks for the heads up.
    2014 Glacier White A7 3.0 TDI.
    Oct 06 2013
    Looks like its definitely an issue! I'd get the new one under warranty if I was you, also!
    Why not, right? Sucks having to lay it down on the turbos and line the cover up... not to mention looks awfully ghetto and cheap on a 85K car.
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    Good to know. I haven't tried removing the cover on mine. Does it just pull off/snap back on, or are there screws involved? Might take a quick look today.
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Oct 06 2013
    Quote Originally Posted by Brooklyn View Post
    4 rubber grommets, one on each corner... just pulls straight up (with a slight tug)! If you haven't, you should... it's awesome underneath!
    Dec 14 2011
    Dublin, OH
    If you're just doing something like this under warranty. Do they still hook your car up or is there any risk for TD1 flag??
    May 08 2004
    NoVA
    probably at the whim of the dealer. Believe Audi's letter to them some time ago basically says to run the scan each time the car comes in for service. Some dealers follow that to the letter, others only run the scan if they need to diagnose a particular problem. Best option is to find a service advisor/tech who will not run the scan unless it is necessary and they have cleared it with you first.
    Oct 06 2013
    Yeah, I don't see why they would... BUT, you just never know.
    Need to get one of these!!!
    http://www.amazon.com/AUTOcyb-CyBlok.../dp/B00AJ42TWY
    Oct 16 2014
    South FL
    This happened to me at around 8,800 miles. My SA ordered a replacement without hesitation, and popped it on in the parking lot a couple days later. The new one has been fine since July, 2014 and some 25,000 miles.
    Oct 06 2013
    Quote Originally Posted by ronbars View Post
    Curious if that was rev 2 or the newest?
    I'll let you know the part number.
    Oct 16 2014
    South FL
    Quote Originally Posted by BlueSVT View Post
    Good question... I'll have to dig around in my paperwork to see if I can find one.
    Dec 14 2011
    Dublin, OH
    Lol. That's exactly what I need!
    Senior Member Three Rings jasonlitka's Avatar
    May 31 2014
    Exton, PA
    Quote Originally Posted by Dguth View Post
    Any warranty work on mechanics or electronics is supposed to have a GFF scan. I don't know that they'd actually need to for a physical defect though.
    Jason Litka
    2016 Audi S6
    Misano Red Pearl w/ Black Comfort Sport Seats, Layered Aluminum/Black Wood, & Black Headliner
    Prestige/Individual Contour Seating/Sport/Driver Assistance/Cold Weather/Black Optic/Night Vision/Rear Side Airbags
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    Quote Originally Posted by jasonlitka View Post
    What is a GFF scan? Thanks.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Mar 02 2009
    State of Confusion
    Quote Originally Posted by VVG View Post
    Guided fault finding test when hooked up via OBD2 port and scanned by Audi
    Oct 06 2013
    Still don't have it back... They found a coolant leak while doing the routine service and checks. Last I heard they had the front bumper off the car, trying to find it! Apparently far down low, behind rad support somewhere.
    This A3 loaner, while fun and peppy at first, is starting to wear on me. Haha
    Oct 06 2013
    Finally got my car back... coolant leak delayed the return, but all good now!
    Anyway, here's the new engine cover in all it's glory:
    I did notice a significant difference in the way it's mounted on the underside. There's a series of plastic tabs that the insulation piece now slides under on the bottom edge, with black push-pins in 2 spots that penetrate the insulation itself! They clearly don't just rely on the adhesive to hold this on anymore (for good reason). I'd say if you have an old style with the adhesive, it's just a matter of time before it falls apart... warranty it while you can!
    Here's the only stamping of numbers I could find... if this is a part number, I'll be damned to be able to decipher it!
    Aug 06 2014
    NJ->CO
    Ok thanks. The 079103925AR is the part number then.
    Yikes $300.
    The old part number that even my 2015 has is 079103925S
    Perf, Leather, Exec
    2015 S6 Quartz Gray
