Results 1 to 22 of 22
    Veteran Member Four Rings Ace's Avatar
    Nov 29 2005
    Belgium
    Mileage per tank with the V6T
    So after driving around with a shitty audi diesel from work for a while it's time to make a decision.
    Thinking about getting a S5.
    But I am really curious what the V6 engine let's you do per tank.
    Normal driving that is.
    Doing an hour long trip to work every day.
    So wanna get a rough idea what to expect should I make the move away from a company car back to something I actually want to drive in.
    Found some number from the V8, but I expect a bit more out of the V6.
    Deactivated Four Rings
    Sep 15 2008
    Is Big
    Fort Worth, Texas
    I get usually between 300-320 per tank in my S4...not sure if it weighs more than the S5. My morning drive is easy, only one on the road at 0400; afternoons is traffic city with lots of stop and go...on the highway. I did get a little over 400 miles on a tank during a road trip.
    Mar 05 2016
    IN
    I have yet to do a per tank as I normaly fill up around 1/2 1/3rd left. How ever When driving to work and speeds at around 60-65mph I'm getting 26-28mpg according to the trip computer.
    2013 S5 estoril blue
    Mar 21 2015
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Saying "per tank" is quite ambiguous considering not everyone is filling up with the same amount of fuel remaining, and also few people run their tanks to empty.
    Manually calculated MPG is the only way to accurately compare.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Senior Member Two Rings Hy Octane's Avatar
    Jan 25 2013
    Depending on how hard I hit the GO pedal, I usually get around 14-16 mpg in the city and regularly see over 30mpg on hiway trips..
    2013 S5 Coupe S-Tronic| Monsoon Grey | Premium Plus | Black Nappa Interior | MMI Nav Plus Pkg | Sports Diff | B&O | Advanced Key | 19" Wheels | H&R OE Springs | H&R Wheel Spacers 15mmF/ 20mmR |
    Senior Member Four Rings
    May 20 2015
    Audi S5 Deep Sea Blue Pearl
    PA
    I wouldn't trust that trip computer estimator lol. It says I get 17-19mpg on my S5 "V8" sometimes if my fiancée drives the car in "D" in the city. Compared to me manually paddle shifting the car. Next thing you know I'm filling up when empty and got 250 miles on the tank lol. I don't rev the RPMs that high up often either unless a highway merge. Or doing a weekly it Italian tuneup real fast to assure the carbon is moving . I can probably get 300 if I do a lot of highway driving.
    I've seen some highway trips say 25mpg which if true would be REALLY good in my case with the 4.2. I've read the V6T & V8 are closer than many think. I'd say it's safe to say you'd get another 30-40 miles or so from the V6T compares to the 4.2 with similar driving.
    Veteran Member Three Rings AbeViator's Avatar
    Aug 16 2013
    I used to average about 18-19 MPG CITY, and 24-25 MPG HWY. My S5 was DSG and I had an intake and exhaust system on my car. If I got on the gas a lot, the MPG drops a little bit and have seen as low as 22MPG HWY/15MPG CITY.
    RS5 SB | Alu-Optic | Sport Exhaust | 20" Rotors | Driver Pkg w/ Side Assist | Nappa | MMI Nav+ | B&O
    CARBON OPTICS | AWE DP | H&R | 1SECARBON | 034 | ECS | EVENTURI | CAPRISTO | ARMASPEED
    Established Member Two Rings IbisB8.5S4's Avatar
    Sep 09 2015
    2015 Tahoe LTZ, 2008 Silverado
    Mount Vernon, WA
    i drive 90% highway and get about 22-23MPG average per tank. i usually fill up when it hits 300milesish on the tank. I think the tanks should have been a couple gallons bigger IMO
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    what app is this?
    Mar 21 2015
    ^ Roadtrip
    Senior Member Three Rings drdrewusaf's Avatar
    May 31 2012
    San Antonio Texas
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    Damn your gas is CHEAP
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    May 31 2012
    San Antonio Texas
    Quote Originally Posted by Sweep View Post
    And that's 93 Octane. I guess Texas is alright in at least one category.
    Drew
    Mar 21 2015
    Quote Originally Posted by drdrewusaf View Post
    Drew
    Ship or tanker to the refinery then directly to the pump. Lucky you.
    May 20 2015
    PA
    Almost $2.90 in PA right now for 93 last time I filled .
    Senior Member Three Rings dseag2's Avatar
    Oct 28 2011
    Dallas, TX
    This looks like my mileage as well. Mix of city/highway. Sometimes up to 22 MPG.
    I have noticed the S5 has a relatively small tank. Seems like I am always filling it up, and I don't even commute.
    '17 Audi A4- Ibis White/Nougat/Premium Plus/Technology/19" Sport package
    '16 Honda Accord LX- Modern Steel/Gray
    '13 Infiniti G37 Convertible- Graphite Shadow/Graphite/Premium Package
    Previous Audis:
    '15 S5 Coupe
    '11 S5 Cab
    '10 S5 Cab
    '09 A5 S-Line
    '01 A6 4.2 (beast)
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Maybe 2 miles of my commute every day are highway miles, and the other 10 each day are on side roads. I average 200-220 per tank, and I typically read 50-60 miles left when I fill up. If I do all highway miles and I'm not goosing it, I've seen as much as 380 on a single tank, which is actually quite nice when you consider my "miles left" gauge never tells me more than 365 miles when I top off.
    I am at high altitude, and there's arguments both ways regarding how gas mileage is impacted by the high altitude. Some say that the thinner air reduces drag and improves mileage, while others argue that since the engine is working harder you get worse mileage. I've always found that forced induction vehicles, especially turbos, get quite a bit higher MPG than what a manufacturer claims, while naturally aspirated vehicles get less. My STI was rated for 24 MPH highway and I usually average 28 to 29 on the highway, and that was with stage 2 mods and goosing the pedal pretty regularly.
    2013 Audi S5 - EPL Stg 2 ECU/TCU
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Veteran Member Four Rings vwblackb5's Avatar
    Jun 26 2007
    New Jersey
    super lulz .. I avg 15-16spg #becauseracecar
    16 B8.5: S4 | Premium Plus | Ibis White | PNY | PPS | GH2 | 1BL | Black Nappa | CTS
    99.5 B5: K04-015 / GIAC PC-16 / 315cc Genesis / Custom FMIC / 034 TP / TT Downpipe / Jetex Catback / Forge 007P / ECS AFPR @ 2.7Bar / ABD Tuning Intake / Blinktek Heatshield / Koni FSD / Eibach Pro Kit / SouthBend Stage 2 Endurance OFE HD / 312mm Slotted A8 BBK
    May 31 2012
    San Antonio Texas
    Quote Originally Posted by dseag2 View Post
    Yeah, I'm about 50/50 city/highway with 5 MPH traffic on the way home from work. Anything you see in that pic above 21 MPG is because, at some point in that particular week, I had a 20-30 minute highway drive that is not normally part of the work week (or I had good luck all week with traffic and stop lights). Over the life of the car I've actually averaged just over 21 MPG.
    When I drove my car from WA to TX, I averaged 25.5 MPG for the trip, but that's the best I've done.
    Drew
    Veteran Member Three Rings SixShifter's Avatar
    May 29 2012
    York, Pa
    This is the first, and so far 'only', new car I've ever owned which didn't exceed/hasn't exceeded the est. highway miles by at least 2 mpg from day one. Only once have I managed to get 30mpg, and that was on the final leg of my second trip back from Texas to PA this past December (str8 up I-81 fueling at Bristol TN to home) sitting at a constant 70mph with just over 30K on the odo. I find the 'true' mpg is normally 1 to 1 1/2 mpg under what the computer states. Even my small block '08 Vette got 30 mpg between York PA and Baltimore ... of course that drive was basically 95% highway driving with only one traffic light (in the parking lot) and stop signs which didn't exist at 4:30 in the morning. I'm currently getting around 25 with normally 4 50 mile runs mixed in with local driving per tankful.
    Jul 17 2015
    Colorado
    ^ I managed to get 59.5 MPG all the way up to Denver Airport, which is about an 80 mile drive for me. I picked up my friend, and he wanted me to do bad things on the way home, so I averaged about 13 on the way home. Denver is technically down hill for us, and I was wayyyy easy on the pedal all the way up.
    I have no idea why or how I managed to get it that high. I should have taken a picture, because no one will believe me except for other person that saw my gauge.
    IG: @MrHazeMyth
