Results 1 to 16 of 16
    Senior Member Two Rings PsorianoPre99A4's Avatar
    Dec 13 2015
    B8.5%20AR%2014%27%20P %20
    PNW
    Question Power Steering pump noisy, anyone want to share what brand they replaced?
    The OEM is pretty expensive to replace, anyone have any luck buying an after market one?
    Sep 01 2011
    Louisville Kentucky
    LOL, I just filled my fluid up... *DOH*
    Oozed from a pustule of thought somewhere within the recesses of my mind...
    Veteran Member Three Rings b5a4erik's Avatar
    Apr 22 2014
    Aptos, CA
    ZF
    Dec 13 2015
    PNW
    Simply filling it up doesn't fix the noise lol. Should I just change the fluid out? I don't think it has at 130k? I feel like the noise will still be there.
    Jan 25 2016
    Just bought this one
    https://www.europaparts.com/power-st...d0145156f.html
    Unfortunately I'm having trouble getting power steering back. Not sure what it is so I can't fully believe it's NOT the pump yet. I think I just pumped so much air into the system it needs a serious bleed.
    edit: I just realized this is for the 2.8 I drive and almost everyone here drives a 1.8 so this probably won't help much.
    Dec 13 2015
    PNW
    https://www.europaparts.com/power-st...d0145156k.html
    Can anyone say they used this and its working good and not noisy?
    Apr 22 2014
    Aptos, CA
    Quote Originally Posted by PsorianoPre99A4 View Post
    I can't, but it's being installed on my car right now.
    Read good things about it.
    Dec 13 2015
    PNW
    Cool! Yeah I saw the price and thought that was really good compared to ECS. Let me know how it sounds and if the fitment is good. Thanks!
    Quote Originally Posted by b5a4erik View Post
    Apr 22 2014
    Aptos, CA
    Sure man.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    I installed a Meyle power steering replacement pump for my b5 2.8 once in 20 degrees fahrenheit because the fluid pick up hose was leaking fluid on the connection right under drivers side fog light and before i noticed, the bearings were shot in the pump and the reservoir was dry. the replacement isnt that bad if you have all the tools you need prepared. i did mine without putting front in service position.
    The Meyle pump still works fine.
    Remember to only use Pentosin CHF 11S
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    I would say OEM. I had a buddy replace his with aftermarket and it's done already. Not even a yea. Installed with a Bentley manual as well. Some parts just save the trouble and go OEM.
    Dec 05 2007
    Vid of noise? Probably air causing it. Keep the level above min.
    Dec 13 2015
    PNW
    Can you recall what one he used? And Where he got it from?
    - - - Updated - - -
    I'll post a vid today
    Dec 13 2015
    PNW
    Finally got a video up for the noise, I've been told by others it's the sound of the power steering going out. Are there any options without replacing it?
    My Daily
    1999.0 A4 1.8TQM AEB Casa Blanca White
    Stage 3 United Motorsports - Vogtland GT3 - Frankenturbo F21L - TR18T FMIC - 630cc - 3" MAF - 3" 034 HFC - 2.5-3" Neuspeed Catback - ECS RA4 Clutch/12lbsteel - OEM Roof Rack - K&N/F21 TIP - DAWES MBC - VDO Gauge - TurboXS DV - 034 PCV - 034 Rear Sway/Subframe - 034 ICM Delete 2.0 coils - Stock Internals
    Veteran Member Four Rings AudiB5owner's Avatar
    Sep 08 2011
    B5 A4 1.8T AWM FWD
    Los Angeles, CA
    Meyle pumps caused me much headache. I went with the OEM ZF pump on the S4 and it runs fine knock on wood
    B5 A4 1.8T FWD
    Sep 30 2015
    Quote Originally Posted by AudiB5owner View Post
    Luckily my Meyle pump has not failed. Made in China for sure though. oem was not an option for me as my local supplier did not have it in stock. You can install oem pump but if you overlook your pick up and return lines, the pump will fail again.
