Results 1 to 23 of 23
    Established Member Two Rings yoshibishi's Avatar
    Jan 29 2015
    NC
    Car violently shaking in 6th gear
    So my car has had an issue with shaking since I bought it. I've replaced a whole bunch of things to fix it, but it is still there. Here is a list of things replaced in last 10k miles:
    Snub Mount
    Motor Mounts
    Diff Mount
    Transmission Mount
    Upper Control Arms
    Front Axles
    Brand new tires, mount, balance, alignment (last 100 miles)
    I originally thought it was something to do with my mounts or tires. It really only shaked around 70mph, but now it is getting worse. I noticed that it isn't that bad in 5th gear at 70mph.
    When I go WOT in 6th gear at any speed, the entire car shakes. This does not happen in any other gear.
    Thoughts? Could it be ignition related and misfiring only in 6th?
    2006 B7 S4 - Work in Progress
    2010 Evolution MR-Touring 340awhp/320awtq - http://imgur.com/a/eeIbp
    ETS Intake | ETS UICP | ETS V2 Quiet Exhaust | ETS HFC | Grimmspeed 3 Port | Seibon VR Front Lip | Rexpeed CF Hood Scoop, Side Skirts, Vortex Generators, and Lip Spoiler
    1992 3000GT VR4 450awhp/430awtq - http://imgur.com/a/dN2UG
    3sx Executioners (16T) | Dejon Intake | Dual Core FMIC | Turboback 3" Exhaust | 5Zigen FN01R-C | Too much to list..
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Do you have hub centering rings?
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Established Member Two Rings 1.8t's Avatar
    Jul 25 2008
    Quote Originally Posted by Lucca M View Post
    +1 what wheels are on it?
    Sprint Blue/Black B7 S4 Avant 6MT - KWV3, Catless Downpipes, Miltek Resonated Catback, Revo Tune, Hotchkis F & R Sway Bars, Flat Bottom Steering Wheel, RS4 Pedals, Ocarbon Trim, Ecs Snub mount, Michelin Ps2, OEM S5 Rotor Wheels, 6 Piston Brembo Calipers.
    Jan 29 2015
    NC
    Quote Originally Posted by 1.8t View Post
    I have the stock OEM BBS wheels.
    Car shakes at any speed in 6th gear when I give it some gas, like the engine is trying to jump out of the car.
    Jan 17 2014
    New Jersey
    When you press the clutch it goes away?
    Insta: luccamentone
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Good question.
    Veteran Member Four Rings bmwpower603's Avatar
    Aug 30 2015
    Derry NH
    Quote Originally Posted by JimmyBones View Post
    Good question.
    Sounds like the flywheel could possibly be coming apart. And damaging your timing cover. OP needs to be careful.
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    Quote Originally Posted by bmwpower603 View Post
    Why then only 6th?
    B6 S4 Cabriolet
    Milltek exhaust w/ SW tips, H9 fogs (DRL), denison Ipod adapter.
    Debadged except the rings, TWM Leopard shift knob.
    TD Pro Race 1.2 Wheels, Continental Extreme Contact DWS.
    Aug 30 2015
    Derry NH
    Quote Originally Posted by IslandHydro View Post
    Why then only 6th?
    He said 5th also.
    Sent from my SM-G900T using Audizine mobile app
    Jan 29 2015
    NC
    It only happens under load, so pressing in the clutch makes it go away.
    Ouch, does that happen on B7s as well? I've taken it to the shop for the past year and they said the vibration is from getting stiffer mounts..
    How much should it cost for a flywheel replacement? I think it may be time to cut my losses and move on to another car.
    Jan 17 2014
    New Jersey
    Its not from mounts. Def not that. Either flywheel or something with transmission.
    Insta: luccamentone
    Aug 30 2015
    Derry NH
    Quote Originally Posted by yoshibishi View Post
    $450 rock auto
    $1200 JHM
    Lol
    $500-$1k labor probably
    Jan 29 2015
    NC
    $450 rock auto
    $1200 JHM
    Lol
    Yea, time for me to move on. Already spent over 10k in repairs this year. Not going to dump anymore into it.
    Thanks for the input.
    Aug 30 2015
    Derry NH
    Wow.. 10k..
    Was timing done?
    Jan 29 2015
    NC
    Wow.. 10k..
    Was timing done?
    Nope. Everything just keeps breaking on this car.
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Wow.. 10k..
    Was timing done?
    doing your own work really pays off
    Aug 30 2015
    Derry NH
    Quote Originally Posted by jakeoboy67 View Post
    Well. I have an oil leak maybe from the valley pan. Tightening the t30s to much. Or front main. Can't tell.
    Apr 03 2010
    Northern Virginia
    Do you know the production date of your car? I am willing to bet that your car is likely a 2005.5 S4. That was kind of a transition year from the B6 chassis to the B7 chassis. So it has a lot of B6 S4 parts. The 2007 and 2008 S4s are true B7s with updated parts in a lot of places. After replacing all the stuff that you have listed, I would figure that you are pot committed to the car. You will likely not get any money out of the car at this point.
    Yes it does. Generally all low production German cars get expensive to maintain with higher mileage. S4s, RS4s, S6s, RS6s, S8s, etc are all good examples of that.
    Jan 29 2015
    NC
    Problem is, I don't have time to work on my car. I drop it off at the shop while at work and Uber back to the office.
    WAUGL78E26A264867 is my VIN, looks like 2006 to me. Sure, I won't get money out of it, but I won't be losing more if I keep fixing it. Might trade it in for a truck to haul my Evo with.
    Apr 03 2010
    Northern Virginia
    The production date should be on the sticker between the driver's door and the body.
    I had to get a truck and trailer to haul my S4 and other cars to different tracks. So I know how that goes. Good luck selling your S4 if you follow through with that plan.
    Jan 29 2015
    NC
    Traded it in for another Evo. I got 10k for my trade in, just an FYI in case people are curious. I did fight them tooth and nail to get that rate.
    Established Member Two Rings Krazed's Avatar
    Mar 17 2016
    San Francisco
    Damn sucks to hear you had such a bad time. Hopefully the EVO will treat you better.
    B7 Audi
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    How many miles were on the car? Seems like a decent trade in considering it needs a clutch/flywheel job.
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
