Results 1 to 17 of 17
    Mar 29 2012
    SF
    Forge DV vs. GFB
    How do the 2 stack up against each other? The Forge is a complete unit and the Go Fast Bits is just the top part right? Is the Forge worth the extra cost to have the whole BPV?
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    I went from a forge DV spacer to a GFB DV+. I highly recommend the DV+. On throttle power is there immediately after shifting, and my too rich at idle code is now gone.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Veteran Member Four Rings vvenom800tt's Avatar
    Dec 04 2011
    Kansas City, KS
    Quote Originally Posted by james12lucy View Post
    That doesnt give any insight to the OP at all. THe DV+is good, im not sure a lot of people even own the Forge unit as its pretty pricey and knowing that the factory rev D is more than capable
    2005.5 Audi A4 Quattro 2.0T 6MT - APR - 034 - Custom 3" single exhaust - 17z Brembo - GFB - Alzor - Kumho - ST - Injen - Swift - Hyperco - ECS - Saikou Michi - PowerFlex - Podi
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    I own the forge DV and have had zero issue with it. I wanted a full proof design and the engineering/quality looked solid. Maybe overkill but so is a lot of the stuff that we do to our cars. I think the DV+ can throw a softcode too.
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Veteran Member Four Rings jerseybrian's Avatar
    Jul 15 2011
    2008 Audi A4 2.0T Quattro QG 6spd
    Boynton Beach, FL
    I've run my Forge DV with open spacer since 2011. No issues. Not a single code.
    REVO 2+ | VAST Meth | RAI HFC and 3" DP | Milltek S4 Exhaust | Autotech HPFP | 145bar PRV | JHM STS | BFI knob | 034 SD MM | ECS RA4 LWFW | ACT RS4 HDSS | QTP Cutout | Forge DV | APR Snub | Deval RS Front | Votexx 3pc wing | OEM Euro Bi-Xenons | Bilstein HD Shocks & ECS sleeves | Eibachs | RS4 RSB | S4 F&R Brakes | ECS S4 Slotted | Hawk HPS | ECS SS lines | FK LED Tails | CF Dipped Diffuser | Innovate LC1 | IE Billet | THULE | PODI
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    I've also been running the Forge for about 100k miles with no issues. I've rebuilt it twice, once with about 40k on it, the second time at 75k. I've also serviced it twice in between the rebuilds (clean and grease). I had the Forge spacer for about 20k miles with no issues as well, but didn't see the point of the noisemaker.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    +1 for GFB!
    2021 Audi S4, P34 Intake
    Dec 03 2008
    2018 SQ5
    Veteran Member Three Rings vierno12's Avatar
    Oct 26 2014
    ny
    I finally got around to install the DV+ and mother of..... . the difference is wow lol. Also not to mention it actually sounds real good. I have heard the forge blow off and it sounds like a fart lol. I cant stand that noise. The DV+ on the 2.0t B7 makes it sound like theres a real turbo in there not just some cheap blow off valve making fake noises
    Mar 29 2012
    SF
    Quote Originally Posted by vierno12 View Post
    Which BPV you running?
    Oct 26 2014
    ny
    Forge DV vs. GFB
    i have the GFB dv+ on top of the latest oem Rev diverter
    Quote Originally Posted by inked_up415 View Post
    +1 for the GFB dv+ with the stock actuator! A must have piece of kit for these engines.
    Enviado do meu GT-I9505 através de Tapatalk
    Established Member Two Rings SamsonKnight's Avatar
    Sep 28 2013
    NC
    Had both. Miss my dv+
    2008 Ibis White A4 FrankenF23, Custom Tuned by Brandon @Breakout Motorsports, Wosner pistons, IE Forged Rods, 1.8t oil pump, 034 hfc, MagnaFlow Mufflers, Cupra R Lip, S4 Door Blades.
    Stage 3 Forum Advertiser Four Rings ModdedEuros's Avatar
    Aug 23 2014
    Philadelphia, PA
    Another vote for the DV+. We run them on every car here at Modded Euros.
    Modded Euros
    Your Source for Audi & VW Performance Parts
    www.ModdedEuros.com
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    If I may I would instead give the Forge 0 out of 10 rating
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Mar 29 2012
    SF
    Quote Originally Posted by Sanjman View Post
    Why do u say that?
    Jul 09 2009
    Cleveland OH Area
    Site your sources sir
