Labree Motorsports cat-back resonated exhaust $799.00- Local Pick Up Only in San Francisco, Bay Area.
Under 12K miles. Paid over $1300.00 brand new from Labree Motorsport. Zero bends or cracks. All hardware (nuts, washer, gaskets included) My S4 was not my daily driver. I've gotten a ton of compliments on this exhaust and literally had a gentlemen chase me down to compliment the exhaust note.
**California Smog compliant
*small chrome blemish on the outer driver side exhaust tip. It didn't bother me, so i left it. Can weld a new tip or re-chrome the original.
PM me if interested
SPECS:
Direct OEM replacement; no cutting or welding required.
2.5" T-304 mandrel bent stainless steel tubing.
5" x 9" oval, 12" long polished stainless steel perforated core mufflers.
76mm dual wall, resonated, polished stainless steel exhaust tips.
12" stainless steel perforated core resonators within the X Pipe. Resonators reduce interior noise without affecting performance.
Standard neck down connection on the front of our X Pipe which bolts directly to the factory down pipes.
2.5" connection on the front of our X Pipe which bolts directly to our down pipes with NO neck down.
Application Specific: 2005.5-2009 Audi S4
All installation hardware included.
Hand built in the USA.
BENEFITS:
Improved exhaust flow and throttle response.
Refining the factory exhaust note by increasing depth and volume.
Reduction in EGT's (Exhaust Gas Temperature) by freeing up back pressure.
Picture off of manufacturer's website:
