Results 1 to 7 of 7
    Established Member Two Rings dean.mohr's Avatar
    May 11 2015
    '01 F150
    Toledo, Ohio
    Question Check Engine Light after hard driving/Autocross (w/Chipwerke)
    This weekend, I FINALLY got a chance to get the S4 out on a little autocross course. As expected, there was lots of understeer and tire squealing, but I can't think of the last time I did something that fun!
    After the first heat (and about 25 minutes of cooldown time in between) I got back in, started it up, and the EPC light was on. No actual MIL lamp. Before I took off, I ran the codes with Carista and got a cylinder 1 misfire in OBD2 and some emergency system active in VAG-COM. I cleared the misfire and ran a lap to see if it would come back/if I noticed any sluggishness. Everything seemed to go fine, and I've even put about 100 miles on it since with no return of the light.
    I do have the Chipwerke, though I think it is set at either 4-1 or 3-1 to be safer. I can only assume that is why I got the warning. I'm thinking that since it didn't come back, it is probably okay now. My initial reaction is that with the extra boost, maybe a cooler spark plug is necessary?
    Just looking for some thoughts!
    2012 S4 Prestige // Ice Silver Metallic w/Lunar Silver Interior // 6MT // Titanium Package // Chipwerke Pro // CTS Turbo Intake // AWE Track Exhaust (105k)
    2001 Ford F-150...with 265k and counting!
    I'll Always Remember You: 2013 Ford Fusion Titanium
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    2022 Q7, 2018 Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    How's your oil level?
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Wheres your windshield wiper fluid level at?
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    May 11 2015
    '01 F150
    Toledo, Ohio
    Quote Originally Posted by GeoJoe View Post
    Fine...
    Quote Originally Posted by fitzydude View Post
    Ah, it was low! Must have been the problem. Checked my blinker fluid, it was almost gone!!! Potential crisis averted!
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    Quote Originally Posted by dean.mohr View Post
    Shouldn't have been the blinker fluid? That's a BMW related issue!!
    Nov 10 2014
    Apex, NC
    did you check the plug in cylinder 1?
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    May 11 2015
    '01 F150
    Toledo, Ohio
    Quote Originally Posted by doug97gxe View Post
    That I have not. Which is cylinder 1?
