Results 1 to 13 of 13
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Lower Control Arm Hitting Swaybar
    I just bought another B5 and its lowered on H&R springs.
    When the car is sitting on the ground the lower control arm is hitting against the sway bar.
    What would be causing this issue?
    When the car is driving you can feel them rubbing together and the front is pretty loose when driving due to them binding.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Aug 24 2014
    Newport Beach, CA
    Was the control arm installed the right way up?
    2024 M3 Comp xDrive
    Veteran Member Four Rings wbrunner23's Avatar
    Jun 07 2012
    1955 Johnson QD-16
    KSQ, PA
    The front sway bar links are installed correctly? If they are flipped to the front of the arm they will make contact under load.
    Idk otherwise, I just went out to look at mine and I'm having trouble understanding how the sway bar and LCA could ever make contact.
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Quote Originally Posted by christianb5s4 View Post
    2nd..
    here is the proper orientation for driver side
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    I'll take a look to see if everything is correct. Last owner didn't mention doing control arms.
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Are they supposed to be in the inner or outer hole?
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    inner. i think outside is for the a6.
    can a sway bar be installed upside-down?
    Aug 24 2014
    Newport Beach, CA
    Quote Originally Posted by Timtheguru View Post
    2nd..
    Oops, ha that would make things difficult to screw up.
    2024 M3 Comp xDrive
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Previous owner installed the swaybar backwards.
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    Quote Originally Posted by Austonwerner4 View Post
    That must inspire confidence in all the other work he did lol
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    Quote Originally Posted by Audi9 View Post
    Well I shouldn't say he did it but he was aware of the issue. I'm happy it's corrected.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Wow
    Dec 01 2019
    OH
    Same prob,were you getting hard steering to the right and easy to left?
