Page 1 of 4 123 ... LastLast
Results 1 to 40 of 137
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    OEM Exhaust w/retrofit black 3.75 double wall angled tips, unitronic DP, OEM Rez. Del
    So I didn't feel like spending $2K on an exhaust now that I have the Unitronic Downpipe and Resonator delete. I love the sound now but hated the little tips on the OEM and wanted black tips anyway.
    Right now they are clamp on, but will eventually weld them on, now it looks and sounds the part.
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Quote Originally Posted by 2015S3 View Post
    How much are the tips? Did they require any modding to fit? Fit a regular s3 valance?
    -cW
    Sent from my SM-G935V using Tapatalk
    2023 X3 M40i Alpine White
    Feb 11 2015
    New Jersey
    No modding of the valence at all just installed a rear carbon fiber diffuser on a friends car with the same tips in chrome and they fit fine.
    You just have to cut right behind the ovals
    - - - Updated - - -
    Tips are like $22 on amazon a PC.
    I got for $100 shipped
    Sep 13 2015
    Hell City, Az.
    well, that looks awesome.
    Can you share the link? or part number, something? me wants!
    Dec 21 2015
    Melhbach, Germany
    All anyone needs to do is take the exhaust tip pipe diameter of the stock pipes. Measure the length you need. Then look online for the size and type of tips you need. The list of exhaust tips available is ENDLESS... every size and type is out there.
    Remember you not just buying the catback exhaust for the sound and looks, but also the aftermarket catback exhausts are much lighter as well. I'll have the weight difference between the OEM and the AWE Track exhaust posted once mine is delivered. I weigh and compare EVERYTHING I install. For some header back installs on some vehicle applications I've seen weight savings of 50-60 lbs or more. Esp. if you dump resonators, cats, exhaust valves (not the ones in the heads...), and the large OEM mufflers.
    2016 Audi S3 (CTS Intake, JB1, dogbone, AWE track catback..)
    2002 Trans Am WS6 (Sold)
    2012 SRT8 (Sold)
    1997 Viper GTS (Sold)
    2006 Z06 (Sold)
    2004 Viper SRT10 (Sold)
    2010 GT500 (Sold)
    Feb 11 2015
    New Jersey
    Common most of us don't care about weight and looking for some options for tips. The weight offset versus WHP is negligible as exhaust add very little performance gains unless you are big turbo, EWG etc. I saw very little gains with my 500 WHP Rotated 2011 STI, downpipes, External; waste gates are a different story. Yes if you go straight pipe back you will see some very good gains at least with my experience. Your vehicle lists look quite extensive and if you have had different experience it has not been mine with turbo-charge 4 cyls.
    The part number is EX-1012B by DC sports 1012 is the chrome number. Like I said I will be most likely welding these on or getting a different one etc. but for now these serve the purpose well and look good.
    I am waiting on my new rear diffuser as I am sure I will need to readjust them another good reason they are movable and bolt on for now.
    Sep 13 2015
    Hell City, Az.
    Blaine,
    You mentioned you weighed the catback (stock vs AWE). What were the results?
    It doesn't compute in my head, or out of principle, the need to spend at least 1.5-2k on a catback, to reduce 10-15 lbs and gain sound sound.
    2015S3,
    Thanks for the part number. I will more than likely be doing this too!
    On amazon, the description mentions that they are mirror-polish finish, on your pictures they are a bit matte. Is that just the camera or me crazy?
    Feb 11 2015
    New Jersey
    The B at the end of all the parts numbers for DC indicate Black.
    I used my cordless saws all it is a handheld version and works amazing!!!!
    Mar 14 2016
    State College/Pittsburgh
    I thought the stock tips were bolted on?
    Oct 30 2012
    Arizona
    Quote Originally Posted by Sepang_S3 View Post
    Nope...just some clips hold the tips on.
    Mar 19 2016
    70 Nova
    Long Island, NY
    What do you mean cut right behind the ovals? I though these were bolt on and you can optionally weld them?
    Mar 14 2016
    Quote Originally Posted by A20V200 View Post
    So you wouldn't have to cut them off, correct? The new tips would slide over the pipe and bolt on
    Feb 11 2015
    New Jersey
    You have to cut the OEM piping is flanged to an oval to match the tips, yes you 100% need to hack off those ovals to get the round portion of the slip on tip to fit.
    I will update pics tonight.
    Dec 21 2015
    Melhbach, Germany
    Quote Originally Posted by selp View Post
    Blaine,
    Won't be able to weigh it until mine gets in. Takes awhile for anything to get shipped to Germany. I'll do a post picture heavy once its in with weights and all.
    Usually I like to my exhaust custom made and tuned for sound to my taste at a muffler shop with tips and mufflers I pieced together to save $$, but since I'm in Germany I don't have that option anymore. So I'm stuck with bolt on kits.
    2012 SRT8 (Sold)
    2006 Z06 (Sold)
    2010 GT500 (Sold)
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    - - - Updated - - -
    Do you have a link to those tips? I really like the black look! Thanks!
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Active Member Two Rings Tdub Lion's Avatar
    Feb 26 2016
    Knoxville TN
    Quote Originally Posted by Baggio View Post
    Same. Link please
    Aug 28 2013
    Mar 13 2016
    San Jose, CA
    I bought a set. I'll report back with some pictures when I get them on.
    Aug 28 2013
    Quote Originally Posted by tateltot View Post
    I just bought them as well. Will post pics when installed.
    Junior Member One Ring
    Apr 19 2016
    KCMO
    I bought one of these some time ago and I gave up when I realized it would not fit without cutting the original pipe, and even cutting I thought it would be a tight fit. I would really appreciate a pic showing the actual connection, the oval section is a long piece so you need to cut a pretty good chunk of original exhaust. I might give it another try now that I know it will work, my original pipe tips are not in a very good shape.
    Feb 26 2016
    Knoxville TN
    So i did mine tonight on the A3 and it was super easy. Just went and grabbed a pipe cutter from home depot and dropped the exhaust down via the two bolts that hold the rubber exahust hangers A few spins and it was off. But for just the duel tips of the A3 i have to say it looks really good. A lot better than the stock (way to small for the holes) tips. Forgot to take before shots
    Sent from my VS986 using Tapatalk
    Mar 13 2016
    San Jose, CA
    Quote Originally Posted by Tdub Lion View Post
    Agreed. Very very nice. Do the resonated tips change the sound at all in your opinion?
    Feb 26 2016
    Knoxville TN
    No not at all that i could tell. Still quite as a mouse just looks a whole lot better lol.
    Apr 12 2016
    North America
    For those who wants to change their A3 dual tips, there are other alternatives as well. Miltek USA has some 100mm tips. The link is for the tips. The video has the miltek catback with the very same tips just so you get an idea how well they fill the holes.
    https://www.ecstuning.com/Search/Sit...100/ES2996373/
    https://www.ecstuning.com/Search/Sit...100/ES3106583/
    Mar 13 2016
    San Jose, CA
    Quote Originally Posted by VWVW View Post
    Those are gorgeous. It's a shame that they're so expensive. $36 vs. those at $175.
    Apr 12 2016
    North America
    Very nice. Would it still fit if I don't want to cut the pipe? What is the OEM pipe diameter at the tip inlet?
    Feb 26 2016
    Knoxville TN
    No you have to cut it just behind the big part where it gets smaller.
    Feb 26 2016
    Knoxville TN
    It wont effect the warranty at all if thats what your worried about.
    Apr 12 2016
    North America
    Not worried about warranty. I am more interested in the Miltek tips which take 3" inlet, so I am just wondering after removing the OEM tips whether the pipe diameter is 3".
    Feb 26 2016
    Knoxville TN
    Just measured and they are are a little under 3 they are about 2 3/4 inches.
    Apr 12 2016
    North America
    Just measured and they are are a lottle under 3 they are about 2 3/4 inches.
    Mar 13 2016
    San Jose, CA
    Had the tips installed this morning. Welded on, $100.
    This might force my hand to finish the vinyl wrap work on the aluminum accents. ;)
    Sep 14 2006
    Wow that looks great
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Looks real nice. Really fills the holes at lot better!
    -cW
    Established Member Two Rings atenzany62's Avatar
    Jan 30 2016
    nyc
    looks nice, what wheels on the car?
    Mar 13 2016
    San Jose, CA
    -cW
    Thanks! (Also, that's what...she/he said?)
    Mar 13 2016
    San Jose, CA
    Quote Originally Posted by atenzany62 View Post
    VMR 710FFs in 19x8.5.
    Sep 13 2015
    Hell City, Az.
    hows the sound?
