Results 1 to 17 of 17
    Established Member Two Rings mahunik's Avatar
    Dec 06 2015
    New York, Clifton Park
    Wastegate chatter/flutter
    I have a 2010 A4 and have noticed that when the RPMs wind down I get a distinct ticking noise of the wastegate. I've already assumed that the wastegate flapper is loose but what I don't know is if these specific year audis has a removable wastegate actuator. Do all B8 A4's have removable actuators? and will tightening this fix the noise?
    Video with noise
    https://www.youtube.com/watch?v=E57i...ature=youtu.be
    2010 Audi A4
    6 Speed Manual
    Premium Plus
    30% Tint all round
    RS5 Honeycomb Grill
    Valentine One Radar
    Weather tech laser fit mats
    110,XXX Miles
    Sep 09 2010
    Destin, FL
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    _
    You can use the thread below to tighten up some slack in your wastegate actuator rod, but ours are not adjustable as they were on the B7s and before. This thread will give you a solution, but I believe it may only be temporary. Used turbos can be had for under $500; which was the route that I took for my car. If you had less miles, or feel like giving it a shot, you can try your dealer. There was a TSB for this, but it's specific to VIN, and the extended warranty was to 70k miles.
    http://www.audizine.com/forum/showth...lapper-(P0299)
    2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW
    1999 A4 Avant | Cactus
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Veteran Member Three Rings S4_SH1640's Avatar
    Mar 15 2012
    Fairfield County, CT
    I have that exact same noise.......
    You think its coming from the wastegate? it sounds like there is some loose heat shield or something like that.
    Garage:
    B5 S4 Santorin Blue Stage 2
    B8 A4 Premium Plus
    D4 S8 4.0T
    Dec 06 2015
    Yeah I thought similar but upon reading more It became apparent that it most deff the wastegate flapper. Other then the noise it doesnt have a major impact on performance unless you're throwing a CEL. My brother who owns a 135 had some really bad wastegate ticking and he checked out mine saying its probably the same thing. For now Im going to leave it be until its gets really bad or when I install a cold air intake/Decat pipe.
    2010 Audi A4
    6 Speed Manual
    Premium Plus
    30% Tint all round
    RS5 Honeycomb Grill
    Valentine One Radar
    110,XXX Miles
    Mar 15 2012
    Mine doesnt throw the code, but i hear it sometimes.
    I wanted to install that wastegate clip but its kinda hard to reach in there and install it.
    Garage:
    B8 A4 Premium Plus
    D4 S8 4.0T
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    I had another P0299 yesterday and I did notice this noise recently from the engine bay. Time to visit the dealer.
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    wasn't there a TSB/warranty extension on the turbo due to the wastegate flapper? I've seen/heard lots of replacements because of it....
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Jul 18 2008
    Scottsdale
    Yes there is an I'm covered since I'm only at 53K Miles.
    Jul 18 2008
    Scottsdale
    Dropped off with dealer this morning with active P0299 fault. Service advisor said they will diagnose and get back later today.
    Oct 23 2014
    _
    Quote Originally Posted by piotrowr View Post
    Good luck! They did the same with me, called me back, and then tried to charge me $150 diagnosis fee + $1,300 not including labor because my car "wasn't covered under the VIN specific warranty extension." I hope you have better luck!
    EDIT: Forgot to add that I came to them with the code in hand, so a diagnosis was not necessary. Needless to say, I did not pay the fee.
    2001 S4 | 6MT
    Gone: 2011 A4 | 6MT
    Jul 18 2008
    Scottsdale
    Just got the call. Turbo is bad and being replaced under extended warranty. Car should be ready tomorrow.
    Jul 18 2008
    Scottsdale
    Picked up vehicle with new turbo. Running better in my opinion, more responsive boost.
    Jun 26 2009
    Bremerton WA
    On these small turbo cars they rely so much on building boost at lower RPM's. A leak at the wastegate is most noticeable in low to mid rpm. At higher RPM there is enough ehaust flowing thru that the wastegate is starting to open anyway. Biggest difference I noticed was going uphill at 25mph. It can stay a gear higher and just turn up the boost to maintain rpm.
    VMR 710's, APR software, Eurocode HFC
    Oct 01 2014
    Pittsburgh/PA/Penn hills
    When I had that error code FULL TURBO REPLACEMENT WASTEGATE, TURBO AND HEADER.
    Jul 18 2008
    Scottsdale
    Quote Originally Posted by van462 View Post
    Yes that's where I'm noticing the big improvement, right off the line at lower speeds/rpm.
    Aug 17 2015
    California
    My car feels a bit sluggish off the line and at low RPM. I have a TON of wastegate chatter when letting off the throttle, but no codes yet.
    Im going to try new plugs, since its been a while. By the way it's a 2011 with 58000 mi.
    Is there any logging I can do in VCDS to see if my wastegate is leaking boost at low RPM? Should I log boost actual and requested while doing a 3rd gear pull? Or 2nd gear from very low speed?
    Thanks for the help guys.
