Results 1 to 2 of 2
    Senior Member Two Rings f4i-pilot's Avatar
    Feb 22 2016
    Hampton, VA
    Post swap stupid PCV
    I am getting a leak between the two red circles and trying to figure out what all I have to replace
    When I first saw the leak I assumed it was the rear main seal, basically cause you can't see the stupid thing. Oil was dripping right out of the bottom of the transmission
    So should I just replace the all the hoses for GP or go to a 034 hose kit?
    Apr 07 2011
    Your best bet is to just go with the kit from 034. All silicon hoses and it replaces all the known failure points in that area. There's a couple different ones depending on your model year so verify with them before you order.
